My Sport-Rider has only 1 engine. After charging the Voltmeter shows 27 Volts.
My batteries are 2x 80Ah Sonnenschein. If the batteries goes out of order, I will buy 110Ah. But the dealer says, do not charge the 110Ah batteries (through) on the controller.
Do I need a switch to disconnect the controller from the batteries, while charging? Or is it right to charge directly the batteries via an additional XLR jack?
Which charger would you prefer to charge 110Ah batteries?
ICEUK wrote:I assume your voltage is to high and when you are doing even the slightest of turns or more power is required for one motor you have no head room from the batteries to supply the motors so your speed gets reduced.
Pierro wrote:Thanks Woody. So the controller is the weak point?
I was hoping that there would be hidden settings that would make it possible. I know there is a different gearbox for the Rider - 20:1 (=20Km/h) instead of the traditional 25:1. But 400 euros.
Users browsing this forum: shirley_hkg and 79 guests
