I have the wheels that BM had, the aeroplane nosewheel, but cannot get it off the wheelchair even though the central bolt and all the bolts holding the wheel together have been taken out. Can anybody help with 2 things;
hank wrote:Are you trying to pull the hub off the motor shaft with the wheel
at the same time.
The wheels split in two halves.
You should be able to pull the wheel off the hubs with 6 screws removed only
as Burgerman said easy.
Burgerman wrote:Seems to me that someone made the hub wrong and forced the wheel on with the bolts. Now you cant get it off. Forced onto badly drilled studs or badly fitting hub centre.
funkykeyboard wrote:Does anybody remember what the valve stem size is?
Users browsing this forum: DrewDigital and 112 guests
