Would those cells be OK sitting on their side?
stevelawiw wrote:Something I did once on my first powerchair to maximise available battery space, take out the battery box and don't use it, so put the batteries in the frame of the chair. May or may not be doable on the Xplore I've not seen it up close.
Alternatively, something I am considering, lower your sights on capacity, save some money and go for something like these instead :- https://www.aliexpress.com/item/4000121191356.html?spm=2114.12010612.8148356.19.7edc2e0d8OsNaQ.
16 would give you 100ah at 24v. It's still a lot more available power than you ever had with lead, and they'll probably fit easy.
Dan wrote:stevelawiw wrote:I have order the 205Ah ones.
stevelawiw wrote:Hi Dan, well done! You've probably done the right thing in going for the biggest capacity available
OK, the magnet sticks to it so I'm guessing its galvanised steel.
Across the top of the box its 265MM but the bottom is only 255MM.
Burgerman wrote:As long as the OUTSIDE edges dont touch any metal And the bottom.
Irving wrote:2mm is overkill though for the separators, but good for the surround.
Dan wrote:Irving wrote:2mm is overkill though for the separators, but good for the surround.
I was thinking of not using any wrap on the cells but make sure they are each surrounded by rubber. Would that be a problem or should I play it safe and use some sort of wrap too?
Dan wrote:If I was to wrap each individual cell in an extra insulator for extra safety what could I use that's easily available in the UK?
Users browsing this forum: acid_coke and 41 guests
