3.00-4 tubeless tyres. Appropriate wheel.
Postby funkykeyboard » 27 Sep 2019, 11:04
I didn't realise you could get tyres this small in the tubeless format. Tubeless would be better because then I can put the slime in for punctures. Does anybody know what decent looking/sexy wheel for tubeless tyres this size?
https://www.terraintyres.co.uk/wanda-p6 ... oFEALw_wcB
funkykeyboard
Re: 3.00-4 tubeless tyres. Appropriate wheel.
Postby Burgerman » 27 Sep 2019, 11:13
Thats not tubeless
Postby Dan » 27 Sep 2019, 12:30
You can use slime with tubes too?
Dan
Postby CPguy » 27 Sep 2019, 12:31
This tyre is tubeless and you can order the rim.
https://www.heba-reifen.at/produkt/vred ... -4-pr-v76/
Edit: If you do not read German order a "VREDESTEIN 260×85 (3.00-4) TL 4 PR V76" with rims from your dealer...
My rides:
2 Progeo YOGA (for traveling)
CPguy
Postby CPguy » 27 Sep 2019, 12:35
@ Dan: Yes, you can but it is not a good idea.
My rides:
CPguy
Postby steves1977uk » 27 Sep 2019, 13:33
I wouldn't use treaded tyres on caster wheels as it would make the chair harder to turn. A smooth/bald tyre has less friction so easier to turn.
Postby CPguy » 27 Sep 2019, 14:57
@ Steve: fair point! But I have not found a threadless TL tyre in that size yet...
My rides:
CPguy
Postby duke1 » 27 Sep 2019, 15:39
CPguy wrote:This tyre is tubeless and you can order the rim.
this tyre is not good wrong shape needs to have more rounded profile square edges bounce of kerbs etc instead of going up them,our size is hard to find in tubeless next to impossible it seems in the uk i recently fitted heidenau tyres to a diy tubeless rim for a friend but to early to say how well it works in use but a homemade seal and a bolt on tyre valve (3mm neoprene for gasket) has stayed fully inflated for 12 days so far,not the best way maybe but if it works it be great,if not i put a tube back later :x peace cheers
duke1
Postby rickystyx » 27 Sep 2019, 16:12
there are these -
https://www.ebay.co.uk/itm/Pack-of-2-De ... SwCFNbUoPW
but I'm not sure it is worth it - if you have moved your centre of gravity back then the castors will float over most things - I'm not sure mine touch the ground very much at all now - my other half gets quite anxious when she is with me and tells me off for pulling wheelies - I don't even know I'm doing it
rickystyx
Postby funkykeyboard » 28 Sep 2019, 15:01
Thanks folks for your interesting inputs, and apologies for my misreading again hanged
funkykeyboard
Postby funkykeyboard » 28 Sep 2019, 15:44
rickystyx wrote:there are these -
Hmmm. Just interested. With your centre of gravity so far back how do you manage ramps, getting in a cab or on a train et cetera?
funkykeyboard
Postby Burgerman » 28 Sep 2019, 16:56
Anti tips, or reverse.
Postby rickystyx » 28 Sep 2019, 17:38
I have antitips but I can also lean my body forward when I need to
rickystyx
Postby funkykeyboard » 02 Oct 2019, 08:42
steves1977uk wrote:I wouldn't use treaded tyres on caster wheels as it would make the chair harder to turn. A smooth/bald tyre has less friction so easier to turn.
As somebody said earlier, where do you find threadless tyres this size? Are they tubeless?
funkykeyboard
Postby Burgerman » 02 Oct 2019, 11:29
Many places. But not tubeless in that size.
Postby steves1977uk » 02 Oct 2019, 14:45
I use these with some OXO Off-Road sealant... https://www.ebay.co.uk/itm/SET-OF-4-X-T ... 2632374829 Never had a puncture.
Postby Burgerman » 02 Oct 2019, 14:53
Tyres that fit 4 inch rims.
https://allterraintyres.co.uk/index.php ... gs3fec5bb4
These are actually smooth... https://allterraintyres.co.uk/index.php ... gs3fec5bb4 And tubes to match.
Postby funkykeyboard » 06 Oct 2019, 17:00
steves1977uk wrote:I use these with some OXO Off-Road sealant... https://www.ebay.co.uk/itm/SET-OF-4-X-T ... 2632374829 Never had a puncture.
the valves don't come out of the inner tubes do they? If not, how do you feel that in the tube with the "OXO Off-Road sealant"?
Is "OXO Off-Road sealant" the same as OKO Off-Road sealant? https://www.ebay.co.uk/itm/OKO-OFF-ROAD ... Sw2cRcb96I
How do you let the air out when the sealant is inside to replace the tyre? Or do you just always replace the in the tube every time you replace the tyre?
funkykeyboard
Postby wheelie junkie » 06 Oct 2019, 17:15
Unscrew the valve core to get sealant into the inner tube then replace valve core. You can deflate exactly as you do with no sealant, just push the valve core. Sealant has a relatively short life span, 6 months to 1 year, it is always worth reading the tech information for each type. From my experience on pedal bikes it doesn't work as well in inner tubes as it does in a tubeless tyre.
wheelie junkie
Postby steves1977uk » 06 Oct 2019, 19:55
Yes I meant OKO not OXO! :lol: czy
Postby funkykeyboard » 07 Oct 2019, 06:09
The valves don't come out of the inner tubes do they? If not, how do you feel that in the tube with the "OXO Off-Road sealant"?
funkykeyboard
Postby Burgerman » 07 Oct 2019, 06:16
Yes valves come out of inner tubes. Screwed in. The bottle top stopper is a key.
Postby funkykeyboard » 07 Oct 2019, 14:28
Burgerman wrote:Yes valves come out of inner tubes. Screwed in. The bottle top stopper is a key.
danke
funkykeyboard
Postby Burgerman » 07 Oct 2019, 19:10
Postby ex-Gooserider » 08 Oct 2019, 00:41
Or be cheap and make your own by jamming one of the caps with the valve core removal end on the end of a bolt....
Some of the tools have extra bits that are supposedly good for cleaning up the threads and such, but I've never found a need for them so why bother....
Users browsing this forum: Google [Bot], hank and 15 guests
