by ex-Gooserider » 08 Oct 2019, 04:15
I would add the possibility that there is corrosion or other crap that is keeping the brake from engaging properly...
There is also a very slight possibility that the connection between the motor and the brake is slipping...
It is probably NOT electrical, as most electrical failures would have tripped an inhibit that keeps the chair from moving and would give an error code on the joystick.
Taking apart and examination is the only way to go.... It's pretty easy on a motor that is out of the chair, harder with it in the chair just because of access...
Typically under the cover you will find some screws that hold the brake coil on, remove them and the coil will come off. The coil assembly has inside it, the brake disk, a pressure plate and a spring. It will have a sort of hex-nut looking socket in it. A bolt the with the right size head can fit in and be turned w/ a pair of pliers on the bolt shank... With power off, you should not be able to turn the socket at all, or only w/ great difficulty... When you apply the right voltage it should turn easily.
Start by making sure the freewheel lever isn't holding the brake open at all...
Then if it doesn't go 'clunk' when power is turned on and off, it suggests that either the disk is frozen in place, or the spring has died - try some wiggling back and forth, possibly some penetrating lube, cleaning solvent, etc. to get it moving, and keep working until it seems reliably free...
The hex socket in the brake fits over a hex bit that will be on the motor shaft - usually there are one or two small Allen setscrews that hold it onto the shaft, make sure those screws are tight, and locked into any flats on the shaft. The hex bit should not have any play between it and the shaft...
Hope this helps,
