Below is some concerns I have had with my 6 mth old Magic Mobility RWD V4 for your information.
I have recently purchased a V4. The chair itself is very good & I'm happy with it. However, the swing away leg rests supplied are a poor design and because of this I find the whole chair unusable.
The hinge under the footplate protrudes 3cm below the footplate and catches on everything eg. gutters, door frame lips, potholes etc. This has resulted in three very bent footplates within six month usage, and potentially could lead to injury.
The locking pin, just below the knee, is made of metal & designed to save itself and ruin the whole $850 leg hanger.
When transferring on a sliding board, the upper part of the leg hanger is too high & restricts the easy flow of the knee when passing over it. This makes it more difficult to transfer.
The cost of $850 to replace the entire leg hanger (no parts sold separately) has made it uneconomical to continue to use the chair. I'm finding myself in the position of having to garage this chair for emergency use only.
I'd be interested to hear if anyone else has found similar issues or a solution to this problem?
