Page 1 of 1
Invacare washers/spacers for rear wheels
PostPosted: 24 Oct 2019, 20:53
by clairc
Hi!
Does anyone know where I can get some washers with a notch cut in them like these? (Number 10 on the diagram)
My hubby bought me some new wheels for my Invacare Fox. The new wheels are for an Invacare Mirage/Spectra and we need washers or spacers to make them fit.
Thanks!
Clair
Re: Invacare washers/spacers for rear wheels
PostPosted: 24 Oct 2019, 22:12
by duke1
hi claire when i needed same for my tinas chair i used these and just use a small file to cut the slot it just depends on size of the shaft it fits over mine was 20mm but some are different so best measure but this is where i got stainless ones,
https://www.ebay.co.uk/itm/M4-M5-M6-M8- ... d54dad5fb5
PostPosted: 25 Oct 2019, 14:19
by clairc
Thanks, duke1. Making the washers was our plan B, I just thought I'd ask to see if I could get hold of any first.
PostPosted: 26 Oct 2019, 02:13
You probably could from invacare.
PostPosted: 26 Oct 2019, 08:04
by rover220
Burgerman wrote:You probably could from invacare.
through a dealer if you supply part numbers, may have to wait a whilst though.
there is a minimum order value so may have to wait until a dealer is placing other orders
PostPosted: 26 Oct 2019, 15:42
by flagman1776
This may be a silly question but unless the shaft key is stuck in the axle keyway, why does the spacer need to be slotted for the key? The key is unlikely to extend into the motor housing where it would interfere with seals. Why won't a correctly sized flat washer do? Does it matter if the spacer turns with the wheel, flanged adaptor, axle against the motor housing which doesn't rotate?
PostPosted: 26 Oct 2019, 15:47
by flagman1776
Google "notched washers" you will find them. Or arbor spacers.
