ex-Gooserider wrote:I purchased a "Hi-Lift Motorcycle Lift" from Harbor Fright and did some serious hacking on it.... I added some spacers to the ground legs so they would fit on the outside of most chairs. I then did some serious changes to the lift forks to make them adjustable in width.... There is a thread on here somewhere w/ photos and more detailed descriptions.
Did find an R-net LED joystick and a ISM6 seating module. Wonder if my old Permobile PM120 will work with these?
Burgerman wrote:Even with error, it can be programmed. Or read the program from your configured chair with the right seating settings etc and send it to the new setup/ chair. If its a bigger amp controller you may need to go to motor section and increase amps. So 100A and 20A boost on the 120A module.
Arima wrote:Guess I can't edit my previous post. Here is updated text to go with the image.
I'll give 18v a try another day.
Yes error because I only have joystick and PM. I need to take back the blank profile...it does have some speed settings so it's not blank. It looks that way to a new user lol. Until you drill down the menus and look closer. So within the top level .r-net profile I can have as many as 8 sub profiles?
My JSM-LED does not have a profile button...only battery meter and speed(?) indicator. Unless the speed indicator is the profile. Bare with me while I learn lol.
Users browsing this forum: Jay_x, shirley_hkg and 42 guests
