I am going to buy replacement gearboxes for my chair. I found them on mobilityscooterpart.com and I contacted to the seller. They sent me the gearbox specs as in the attached images underneath. The ratio 25:1, shape, dimensions are all correct. But I do not understand about the parameters e.g 300W/5300RPM. Do they match the motor specs? My motors are 450W but I do not know their RPM.
The seller asks me if I need 300W/5300rpm/25:1 or 450W/25:1 gearboxes? I am confused, does a gearbox have a power e.g 300W/450W? And does a 450W gearbox has the same size as 300W or bigger? How can I calculate the RPM? My chair speed is originally 12.5kph with 14inch wheels.
I've purchase from them a couple of times. I reckon they're a really good company.snaker wrote:I found them on mobilityscooterpart.com and I contacted to the seller. They sent me the gearbox specs
Motor watts dont tell you a thing. Two identical motors, spray one black, and it radiates heat better. So now its a higher wattage motor.
Good point (and it's the same principle with cables)
Most AC motors have lateral cooling vanes running down motor and a fan at one end to draw the air over them. DC mob motors could have low profile cooling vanes moulded into the casing. They wouldn't need to be that pronounced or necessarily need a fan, and would surely act as a better heat sink than a smooth steel/alu casing?
Yes/No?
But then I suppose if they were needed mob motor manufacturers would incorporate them?
Users browsing this forum: No registered users and 66 guests
