horsound wrote:Hi everyone,
I've been using a Invacare Bora electric wheelchair for the past 10 years, but I'm now searching for a more comfortable powered wheelchair, and I'm trying to educate myself on this subject. In particular, I'm trying to find the type of chair that allows the smoothest ride. I need to use the wheelchair indoor and outdoor, and the sidewalks and roads where I live are quite bumpy, and unfortunately I'm very sensible to bumps due to weak back and neck muscles.
I know each wheelchair model is different, but at least generally speaking is there a specific chair type that is clearly more comfortable? I guess my question is should I choose a front-wheel, mid-wheel, or rear-wheel powered wheelchair? Which one is the smoothest when going over an obstacle?
I've been reading a lot of articles, and also Burgerman's advice here (viewtopic.php?f=2&t=5624), besides many other threads, and initially I was leaning towards mid wheel drive, due to seeing some YouTube videos claiming those chairs were extremely comfortable, but I think the general consensus here is they aren't. Which makes sense, since most (all?) don't have suspension on the middle wheel.
I don't have full control regarding which chair to choose, that's mostly dependent of my doctor and available budget, but I'm hoping to at least try to push him in the right direction. There are only a few brands available in my country - Invacare, Permobil, and Sunrise Quickie - I think the main candidates are the Invacare Storm 4, the Permobil F5, and the Quickie Q700 or Q500 - and hopefully when the time comes I'll be able to know very well all the possibilities and steer the doctor into the right chair.
I was surprised by the negativity here towards Permobil, I thought it was considered a very good brand (and I have to admit I absolutely love their design, I think their chairs are beautiful, in particular the F5), but in the end of the day the most important to me is comfort. Well, I also need 50° tilt, and ideally also 5 or 6mph speed, and that the chair isn't very wide, but ride comfort is really the most important factor.
Thanks in advance for all comments and suggestions. I'm very glad to have found this forum, it seems many people here have a huge amount of knowledge, and even make significant changes to their wheelchairs (which I have to confess never even crossed my mind). Unfortunately I can't go that way, I need my next chair to be as good as possible without custom changes, but my geek side is loving to see what's possible.
shirley_hkg wrote: Storm 4, but Xplore only , because it has front arm suspension .
Then change to pneumatic tyres .
steves1977uk wrote:Avoid anything Invacare these days, the Storm 4 has major issues if you're a heavy user and their lower powered chairs are virtually un-programmable which means they'll never steer correctly. Permobil gets negativity here because of their overcomplicated design which causes a lot of unneccessary problems which could've been avoided, but can be programmed to steer correctly due to the R-net control system.
Sunrise Medical powerchairs are the mostly recommended on here, but need a few mods as shown here... viewtopic.php?f=2&t=7455&start=600#p122818
Burgerman wrote:Generalisations.
1. Anything with small caster wheels (less than 9 or 10 inches) will cause the teeth to be rattled about on what passes for pavements.
2. Anything with less than grp24 (70 to 80Ah) batteries is going to be problematint with short lifspan, less range. In a word battery issues with outdoor use.
3. At 6mph you need 4 pole motors, and 100 or more Amp controller. Less, and 2 pole, avoid... And before buying ANY chair be sure that you can get hold of an OEM level programmer. Or it will always drive like a drunken sailer. That basically means R-Net nowadays... Beware permobil as they use a lot of one off permobil only seating, and stability modules meaning that you will be relying on them when it goes wrong. And judging by the posts here they seem to do that a lot.
4. Rear drive (once you move the seat back, use a centre footplate etc, are much better at outdoors, and stability at speed. Front drive are good on curbs. Are naturally directionally unstable. And so must be fitted with a stability module. This means they can actually go 6 or 7 mph without spinning around and facing the wrong way. But you can feel this working, and it removes the stick authority and so they feel distinctly odd at speed. Both rear and front drove can be very comfortable outdoors as long as they have large casters, and suspension.
Rollin Positive wrote:I think as your looking for a new chair its important to talk to those people off line by email, text or messenger.
There is a lot of generalization based on people that have never ridden a mid wheel or front wheel drive.
There are also end users that have never tried other brands so they are brand specific when the talk about there preference.
Having come from a rear wheel drive then changing to a mid wheel when they 1st came out and then trying a front wheel drive major differences.
One issue with mid wheel is getting stuck a lot when you get on steep inclines, gravel, wet grass or mud.
They are ok in tight areas but you still have castors getting in the way and when casters spin it can really cause wall damage, appliance damage etc.
In a front wheel drive you dont have front casters getting in the way so your closer to doors, tight areas etc.
I agree stick with anything that supports 24 size batteries anything smaller nf 22, or 32 size batteries will impact your rolling.
Work with your providers try and get weekend demos at your house and use the chair as much as possible in your home, roll to a store, market, church, school etc.
If you use transportation train, bus, shuttle then use the demo chair here too to make sure it fits your life style.
Your 100% on Permobil bias here I was told when I got my front wheel F3 it was a terrible ride but its one of the most comfortable and durable chairs ever.
Plus there are a lot of Permobil users that agree. Just need to search them out.
I also roll in a Frontier v6 its a mid wheel and great comfortable ride if your a person that is outside a lot!
Take your time and compare on your own then ask questions of other users of the chair your trying!
Thanks Rollin Positive. I'll try to try several chairs when the evaluation process occurs, but I'm not very hopeful. However, I have to say that on my RWD Invacare Bora the driving performance is perfectly acceptable for me. Definitely not comfortable, but besides that it's ok. I'm sure it could be better, and maybe I'd be amazed if I ever could try am ''ideal'' chair, but maybe this is a situation where the expression ''ignorance is bliss'' applies.
I acquired a stock Invacare TDX SP2 NB a while ago and while being older it has the ability to be programmed, I was pleasantly surprised to find that it steered perfectly so needed no reprogramming at all. I may just have been lucky.
I have also found no issues at all with my front drive Handicare Puma 40 at its maximum 6mph. I like its indoor manoeuvrability.
ex-Gooserider wrote:It would be helpful if you can go to the User Control Panel near the top of every page, and fill in at least your country... This is an international forum and it helps us make suggestions that are appropriate to where you live..... It can also be helpful to tell us a bit about yourself, particularly about what your disabilities are (you mentioned being a quad, what kind of hand / arm function do you have as an example) We don't need medical history details, but the sorts of things a good evaluation for a chair would ask are useful....
2 vs 4 pole motors
Can someone please explain why 4 pole motors are better? It seems everyone agrees on this point, but in any case I'd like to learn why. I tried to Google it, but I didn't find specific info regarding wheelchair motors on this subject.
Batteries:100 Ah or more
I don't know much about batteries, but is there any advantage on getting a bigger battery besides not being necessary to charge them so often? I'm asking this because I don't ride many kilometers per week, sometimes I only charge my current chair once a month! I'm guessing that if my next chair has a much better suspension I'll drive it more, but not even close to what some users here drive.
min of 100A or 120A control system
Burgerman mentioned this above, and also on other threads, but can someone please enlighten me on the importance of this subject? (Sorry again for my lack of knowledge on this area)
Foot rests - swing-away vs single
I saw this subject mentioned on other threads, and I like the idea of having a single foot rest, it'd improve the maneuverability indoors (I have tight corridors and doors), but I'm wondering how/if the single foot rests are supposed to be removable when the user gets in/out of the chair.
horsound wrote:2 vs 4 pole motors
horsound wrote:Batteries:100 Ah or more
horsound wrote:min of 100A or 120A control system
horsound wrote:steves1977uk wrote:Avoid anything Invacare these days, the Storm 4 has major issues if you're a heavy user and their lower powered chairs are virtually un-programmable which means they'll never steer correctly. Permobil gets negativity here because of their overcomplicated design which causes a lot of unneccessary problems which could've been avoided, but can be programmed to steer correctly due to the R-net control system.
Thanks. I've been wondering about Sunrise Medical's chairs reliability, I wasn't aware of them until very recently. Is it an European company? I tried to check on their website, but didn't find information about that.
Regarding the issues you mentioned on the Storm 4, can you please elaborate on that? Do you mean, reliability problems?
horsound wrote:Thank you very much for your posts, guys.shirley_hkg wrote: Storm 4, but Xplore only , because it has front arm suspension .
I'll try to check the differences between the regular Storm 4 and the Xplore, thanks.steves1977uk wrote:Avoid anything Invacare these days, the Storm 4 has major issues if you're a heavy user and their lower powered chairs are virtually un-programmable which means they'll never steer correctly. Permobil gets negativity here because of their overcomplicated design which causes a lot of unneccessary problems which could've been avoided, but can be programmed to steer correctly due to the R-net control system.
Regarding the issues you mentioned on the Storm 4, can you please elaborate on that? Do you mean, reliability problems?Burgerman wrote:Generalisations.
Thanks Burgerman. Modding/changing a chair is definitely not something I could do, I'm tetraplegic, and don't really know anyone nearby that would be willing to make the necessary changes. Unless the shop selling the chair would make them, but I suspect they wouldn't. And after reading your post I'm even more worried than before, lol, because RWD seems to be only acceptable after making the described changes, and FWD seems to be even worse, unsafe at high-speed, or at least have terrible handling.
Your comment about small caster wheels makes me wonder if it's easy to increase the size of the caster wheels in all chairs. For example something like the Quickie Q700, or similar, the caster wheels are relatively small, but due to the design of the chair it's inevitable that the chair tilts significantly, if bigger caster wheels are installed. The chair would be tilted forward or backward several degrees.Rollin Positive wrote:I think as your looking for a new chair its important to talk to those people off line by email, text or messenger.
As a designer I can't fault F3 visual design, I wish all wheelchair manufacturers learned from Permobil in that regard. Not necessarily copying it, of course, but making their wheelchairs aesthetically pleasing. I think it'd help a lot to integrate wheelchair users in society.
But since you mentioned your F3, may I ask if you regularly drive it at full speed? And from your experience, is it perfectly safe, or do you have some reservations about the handling at high speeds?
But also you do not need to by a DYI user like some here to get a good comfortable chair! You also do not need to think that a chair you get will not work good and be relible in less you modify it thats just not true!
Burgerman wrote:But also you do not need to by a DYI user like some here to get a good comfortable chair! You also do not need to think that a chair you get will not work good and be relible in less you modify it thats just not true!
IF your supplier can do all the fine tuning, joystick positioning, etc then thats true. From 22 years in a chair, and going to spinal injuries units, dealing with suppliers and our WCS all I can say is that this is a big IF. As for programming, non of them can or will do that for you. If you dont much care how accurately it drives, then no need to get hold of a programmer. However, many here were of the same opinion. Till they took a little advive. And I would like to bet that NON will ever want a chair that they cant program at the OEM level themselves in the future. So this above all depends... Certainly doing a little fine tuning, positioning, adjusting seat and arm and contoller position, and maybe moving sticky out lights further inboard, shortening push handles or other brackets etc isnt essential. But certainly helps! I never found any test chair that was any good, as tested. And it totally colours the experience, unless you understand why, and how it can be changed.
2 questions.
Will you allow me to program your chair, make sure you have correct joystick position and technique, and then repeat your honest opinion?
Both my Pumas, on the other hand needed to be extensively reprogrammed using your excellent guidance and a borrowed OEM kit. As you often say, before that they steered like hover craft. I have the wrecked doorways to prove it. I was really responding to your rear drive recommendations rather than programming for these.
Burgerman wrote:Hal 9000
horsound wrote:Burgerman wrote:Hal 9000
Indeed. I love ''2001''.
But regarding the feet position, basically both feet need to be strapped to the foot rests, and even being strapped they still maintain a certain angle, I'm guessing something like 20 or 30°. I'm afraid I never took close attention to single foot rests, maybe there are some that allow each foot to be strapped at a certain angle, independently, but I'm not sure.
I'll try to speak with my physiotherapist, maybe she knows if it's possible.
jeffreyclay wrote:I've had two different styles so far. A FWD and MWD. The change over to pneumatic tires for the drive wheels may a very noticeable difference for me. You'll likely not notice it until you go outside and ride some sidewalks. The recommended tire pressure seem too high to me and likely to wear out the center of the tire. To arrive at my tire pressure I wet the tire and drive noticing the contact patch left on the dry sidewalk. I inflate only to achieve a full width patch, usually around 14psi with my tire size and rider/chair weight combination. That gives good tread life, a very slight sidewall bulge that soaks up impact from height changes in the concrete sections (or bricks) while ridding. The wheels that I pulled solid tires off of had the hole for the inner tube valve present so a set of tires and inner tubes were all you needed.
Users browsing this forum: martin007, Raro, steves1977uk, woodygb and 53 guests
