Burgerman wrote:Looks high. And heavy. What do you intend to use it for?
greybeard wrote:Yeah. 85mm seems a bit high for getting under most stock powerchairs. The lowest I've been able to find has been 73mm and that's still too high for my Puma 40.
Burgerman wrote:So how do you use that to swap a wheel?
terry2 wrote:I got this one https://www.ebay.co.uk/itm/Floor-Car-Ja ... 14795cb5f5
I will make a wooden plank to fit the battery box in the middle.
rover220 wrote:terry2 wrote:I got this one https://www.ebay.co.uk/itm/Floor-Car-Ja ... 14795cb5f5
You don't lift the chair with that. Will fall over.
Burgerman wrote:So is what you bought! And too heavy.
expresso wrote:terry2 wrote:I got this one https://www.ebay.co.uk/itm/Floor-Car-Ja ... 14795cb5f5
i have one just like that also - it works for changing tires - depends where you put it - - if right under the battery box from the rear - that can work for both rear tires off the ground - it worked on the bounder that way -
shirley_hkg wrote:Burgerman wrote:So how do you use that to swap a wheel?
Lifting a chair is for the sake of volunteers who perform free maintenance for us.
I change tyres myself.
Users browsing this forum: martin007, Raro, woodygb and 85 guests
