martin007 wrote:Where are you from?
United States?
martin007 wrote:The task you plan is great.
You are self-taught or a professional?
Martin King wrote:martin007 wrote:The task you plan is great.
A self taught professional, the two things are not mutually exclusive.
Martin King wrote:Hi I'm looking at helping someone RC his custom off road wheelchair, part of the reason is so he can drive it back to a safe space from his boat then drive it back to the boat when he returns, he's using a P&G drive. From what I gather the two main options are Can bus control or fake the joystick signals. He'd need to retain the existing joystick but also be able to lock that out for security reasons while it can still be driven by RC. I'll be building a custom high reliability waterproof floating long range radio controller not using commercial off the shelf RC kit. I'm thinking R-Net Can bus control is probably the way to go but I'm having trouble piecing together where that's at with regards to protocol information? I'd also be interested in advice on how to buy P&G programming units (or are there's any "hack" options for that?) although that's less important.
Cheers.
Martin.
rickystyx wrote:Woody that is a superb bit of kit - can you Pm me the cost of it?
I suppose the joystick can still operate as normal as well so do you have to have different profiles specifically for the remote or can you select the profile from the phone?
Martin King wrote:Sorry for the delay in replying, thanks for that, think that'll be the way to go. BTW what are the options for obtaining P&G programmers? At the moment he has to drive a 140 miles round trip to the nearest place and as he makes/tweaks his own chairs it's a major PITA every time he wan't some changes making. From what I've read there seems to be OEM and "dealer" versions but I'm not entirely clued up on the differences and availability but I assume OEM is hard to obtain and dealer very hard to obtain?
Martin King wrote:... So, just to see if I've got this right or am completely up the wrong tree :-
There are two levels of P&G software, OEM (Good) and Dealer(not so good)?
There is an older version that uses USB serial via an XLR plug and a newer version that uses CAN Bus (R-Net) for programming?
For the older version you can just use a modified off the shelf USB serial lead but the newer CAN based version has some security "stuff" in the dongle so it also acts as software copy protection and not just as a programming lead?
Does this seem about right?
Users browsing this forum: shirley_hkg and 131 guests
