What would happen if Inhibit Alarm set to ON ?
But he will say its too complicated.
Burgerman wrote:Simple dummy way ...
You see where it says ASSIGN on the left menu? These are TWO inhibits. 5 and 4 can be changed to OFF. Do one at a time. And test to see which one slows the chair when recline/backrest is operated. The other will be lift or recline. Its a blunt instrument way! So you cant go wrong!
i checked and you cant adjust it - they are all set at 100 - what i can adjust and i did to my chair was the speed it moves once its all the way up
i dont recall exactly where i made that change -
yes i have - when you say chairs max speed - you dont specify -
Users browsing this forum: No registered users and 74 guests
