Can anyone (John) tell me the dimensions of the R-net 120A PM? Also, the ISM-L?
Cant measure. Stuck on bed. But for visual reference:
viewtopic.php?f=2&t=8857
Well, after some delay I finally got the chair today and... it's back at Numotion so they can move the aftermarket back rearward a bit. It's 28" wide with off road tires, but strangely enough the fenders appear to stick out the farthest.
Burgerman wrote:Well, after some delay I finally got the chair today and... it's back at Numotion so they can move the aftermarket back rearward a bit. It's 28" wide with off road tires, but strangely enough the fenders appear to stick out the farthest.
Seat depth, back position and depth, CG position, footplate position, headrest position height, angle, depth, seat width and arm rest width, seat depth, and position, as well as joystick position, suspension settings, seating dump base angle, tyre pressures and a couple of hours and finally geting programming correct is and should be something they do ON DELIVERY as a matter of course with every chair.
It will always take a morning or an afternoon depending on what is required. Unless all of these things are corrected and configured properly for every user then any new chair will always feel and be horrible to use for the whole time you have the chair. This of course seldom happens. But theres really no reason to return a chair just for a aftermarket back to be fitted properly or adjusted in position. Its a 10 minute job!
Burgerman wrote:Mudguard?![]()
Can be moved, adjusted, cut narrower or whatever.
youtu.be/LxkBwa3X5d0
expresso wrote:the bounders are steel and welded all over - its not just a simple screw and move - the canes are welded - if they need to move - they have to unweld it -
its build like a thank - very good - a little too heavy but comes in handy also - wheel shake - if it happens on a bounder - you may not even feel it -or if its bad you may feel it but it dosnt rattle the whole chair and bring you to a stand still to make it go away -
since i moved my casters - i hardly never get it now unless i go super fast on hills etc, it depends -
curious to know how the bounder feels with Rnet -
Cool, thanks. May take to a bike shop or auto place first. I'm getting my first Covid shot next week.
Fusiongoat
expresso wrote:did you get lithium pack ? my charger was smaller - for lithium 10A - i dont use it -i use the PL8 direct - hard to see the rear tires -
pretty cool to have rnet now - gives you alot of options to play with - and raise voltsmore speed -
Burgerman wrote:Those rear guards. What were they thinking!
Users browsing this forum: Arima, Bubbernator, Burgerman, DirtinLa, Frank, Google [Bot], Heygnow, Jay_x, MarkFox, Roadrunner, Rollin Positive, rover220, wes4dbt, woodygb, Yennek and 52 guests
