Chrysler 2004 T&C Entervan Ramp Not Folding
Postby garriew » 17 Sep 2016, 00:03
Two issues:
1) The ramp on my 2004 Braun Entervan isn't folding. When I press the button either inside or on the keychain it lifts may be an inche on the corner closest to the motor then it stops/drops back down.
It will unfold just fine.
2) The kneel function is no longer work. You can hear the motor turning but it doesn't go up or down. I did turn the kneel function off but if it can be fixed fairly cheaply I would like to get it fixed.
As always, thanks for your help.
garriew
Re: Chrysler 2004 T&C Entervan Ramp Not Folding
Postby Burgerman » 21 Sep 2016, 11:49
Kneel sounds like the chain under the van has failed. The ramp could be a motor, or a cam/microswitch that needs looking at.
Postby garriew » 25 Sep 2016, 02:44
The ramp ended up being two lose bolts on the ramp.
garriew
Users browsing this forum: No registered users and 4 guests
