The car itself will have some continuous, parasitic drain too. Even without the lift etc.,
Thanks, I will definitely look into fitting a solar panel. There is a huge expanse of almost flat dashboard on top so it may well fit on there.
Fit a 30 watt solar panel, and a tiny charge controller, on the roof, laid flat - not a window. Not a temporary solution.
Since the yellow top optima's are very expensive batteries, I am not keen on replacing them until they die, but I may link them in parallel and get rid of the split charging system.
A. dash not big enough.
B. as soon as you have it shaded, by a roof, face wrong direction, etc you lose most of the days sun hours.
C. as soon as you put it behind a windscreen you lose most of its power regardless.
Doing that is a waste of time and money, and will result in a dead batter at the same time.
These are the batteries - both the same.
A couple of crimp connectors *fell* off the end of the wires!
Users browsing this forum: No registered users and 32 guests
