VMI issue
Posted: 20 May 2017, 15:25
So I've got a VMI honda Odyssey and I've been noticing my steering was feeling a bit wonky for quite a while. Last year I took it in for an alignment, which was fine. A couple months ago I take it in to the Honda dealership for a timing belt. When they put it on the lift the front wheels dropped out of the wheel opening. Come to find out the nuts that hold the front struts to the strut tower were all broken off and gauging by the rust on the studs they have been broken for a long time. When VMI raises the suspension on the front they use what looks to be an aluminum casting about 4 inches thick the machine stud extensions with a female thread on one end and male on the other. The studs, 3 on each side were all broken under the nuts.
When I went to the VMI dealer he told me they have seen this 5 or 6 times. I called VMI directly and told them they should have a bulletin on this but all I got was lip service saying this "is an isolated incident", which is a load of bull. Incidentally my van has never been in a collision nor has never even kissed a curb. So if you have one you might want to do a little inspection to see if yours are broken. I have a couple pics but cannot get them to post. I can email them if any body is interested.
