Hi All, Greetings from New Zealand
Postby ADI8421 » 23 Nov 2023, 19:30
Quick Introduction: I'm a retired electronics hardware/firmware engineer based in New Zealand, recently confined to wheelchairs and mobility scooters. 10Km/hour forward speed isn't enough for me, so time to start hacking.
So I've figured I need to build a 'DWIZ-ADAPT' type Programming Adaptor ie. Separate TX/RX to 'One Wire' serial adapter.
I already have an FT232RL FTDI USB To TTL Serial Adapter.
If anyone can help with a link to the 'special' version of Wizard 5 I would be forever grateful.
Many thanks in advance.
Cheers Jim
ADI8421
Re: Hi All, Greetings from New Zealand
Postby Burgerman » 23 Nov 2023, 19:47
I can. But it wont make it faster. Unless someone has reduced speed for some reason already. Speed is a function of battery volts and gearing. And it cant go faster without adding more volts than your battery gives you.
PM me.
Postby martin007 » 24 Nov 2023, 18:15
Welcome to the forum.
Postby ADI8421 » 24 Nov 2023, 19:24
Thankyou Martin.
martin007 wrote:Welcome to the forum.
ADI8421
Postby ADI8421 » 24 Nov 2023, 22:10
Thanks for your help Burgerman. Successfully built and tested the ADWIZ-ADAPT pcb etc.
Works great !
Cheers Jim
Burgerman wrote:I can. But it wont make it faster. Unless someone has reduced speed for some reason already. Speed is a function of battery volts and gearing. And it cant go faster without adding more volts than your battery gives you.
PM me.
ADI8421
Postby Burgerman » 26 Nov 2023, 11:20
Was it possible to increase speed?
Postby ADI8421 » 27 Nov 2023, 20:27
Burgerman wrote:Was it possible to increase speed?
Speed was already set to 100% maximum, but it did solve my Forward Deceleration problem which was set far too course.
ADI8421
Return to Introduce Yourself!
Users browsing this forum: Bing [Bot] and 5 guests
