Recently got my first powerchair, a used Quickie Freestyle M11.
This was a true 'godsend'........I dearly love being out and roaming about but since accident in '85
my walking ability was severely limited
So far I've bought new batteries and new tires--(solid foam-filled).
The front caster housing needs bearings.-(for vertical shaft)
Is it possible to determine what bearings to order WITHOUT dissasembling the caster assembly?
As for accessing the vertical shaft, I can't get to the top nut.....there's 2 small screws that refuse to loosen,
even after WD 40 and hammer taps
The Quickie's range on a full charge is appx 5 miles.
Is it possible to increase this?
It takes 4 hours to fully recharge.
Is it possible to speed this up?
