bobbit wrote:Many thanks for the good advice, if I buy a chair on eBay what am I looking for? I have ms and can only use my left hand properly, can the controls be moved from one side to the other for example, and how good are the batteries that are used(they don't seem to be lithium) and is the range quoted accurate? As I said I am a complete novice at this!
B
[Disclaimer: I don't use a chair so my comments are solely "from observation"]
You have to decide how much a part of your life the chair will likely be -- now and in the future.
Think about your physical size. You don't want to be shoe-horned into a chair that is too small for your frame; nor swimming in one that is oversized! Do you need any special support for head, arms, legs, etc.?
Are you comfortable sitting in a *single* chair for the periods of time you are likely to be in the powerchair? Or, do you need to adjust your position within the chair, often? You may want/need a chair with additional "controls" to manipulate your seated position (recline, upright, etc.)
Will you rely on it to get around your home? Or, just "while out"? Think about what your house looks like and how it may accommodate -- or hinder! -- the use of various styles of chairs. Chances are, your house wasn't built with the requirements for a chair in mind!
If you expect to regularly transport the chair ("doctor's appointment"), what sort of vehicle do you plan on using to perform that task? Will you be using an "outboard" lift? A van with internal power lift? Or, perhaps, a "community provided" service (like a mini bus designed to accommodate chairs)?
Look at your current -- and likely future -- physical condition. Is it relatively stable? Or, likely to change "soon" (whatever THAT means!). E.g., is your MS progressive or relapsing? How frequent are your attacks? etc. (Note that I am not asking you to answer here, publicly; rather, just suggesting something that you should consider in choosing what your needs are LIKELY to be in whatever timeframe makes sense for your decision process). Left/right handed controls are usually easily accommodated -- just slide the controller out of the current armrest and move it to the *other*. There are also other types of controls that can be used in the absence of fine hand control (mouth stick, head switch, etc.). But, fitting them to any particular make/model of chair may require some research.
Depending on your location (country, city, etc.), you may find organizations that have chairs for temporary loan. You might consider requesting something like this just to get a feel for what you do and don't like about *a* chair -- to help you better formulate your own preferences. These organizations tend to support *their* equipment (e.g., chairs) and don't have a financial interest in "making a sale" -- so, you are likely to get less biased information. You could be more comfortable asking their staff (usually volunteers) which chairs they have the most problems and/or complaints about.
Here (USA), many "mobility vendors" will be happy to set you up with a "trial". Of course, they assume you'll just try THEIR chair and the trial will result in a sale. Read anything you sign to be sure you're not forfeiting your decision!
I've commented (elsewhere) on how frequently chairs are seemingly scrapped -- in working order (with the notable exception of spent batteries). Asking around, you might find something to use as a "starter" before committing to an actual purchase (especially if your insurance company is involved in that eventual purchase -- chances are they won't be happy about a *second* purchase if you decide you don't like the first one they purchased on your behalf!)
[Note, batteries are ~$200 for a pair -- depending, of course, on the size required for the chair and how extravagant you want to be. If you are just "experimenting" with a chair to get an idea what you like and dislike -- i.e., you aren't planning on keeping the chair "long term" -- then you probably don't want to invest heavily in batteries.
THE BATTERIES FOR ONE CHAIR WILL PROBABLY NOT PHYSICALLY FIT IN ANOTHER CHAIR! So, don't think you can "pull" those nice new batteries that you purchased and move them into your next chair -- unless you planned for this explicitly!]
Obtaining a chair *without* some plan for supporting it (maintenance) is probably not wise. Who are you going to call WHEN the chair doesn't work? Do you have the skills (physical and mental) to perform these sorts of activities? Or, will you have to rely on someone else (agency, vendor, etc.)? The type of support you get from a mobility vendor for a chair that you bought second-hand might be suspect -- is he telling you that the motors need to be replaced because he's trying to drum up some business for himself -- repair or new sale? How likely would he be to make a similar diagnosis if he had sold you the chair *new* -- and, that repair was covered under warranty? (How likely would you be to buy ANOTHER chair from him if he had sold you a chair that needed such drastic repairs??)
Good luck with your chair decision -- and your fight against the MS!
