Its a bit overkill just to charge your multimeter. I got one as I have a good few 18650 cells, 21700 cells etc here. Used in lots of hobby stuff. And torches etc. And because I have AAA and AA in many TV style remotes for heating, doorbell and alarm stuff and light controllers and stuff.
Its just convenient to grab the cells from everything at once and charge the lot in a marathon evey now and then so everything is full! Including 3 multimeters, other tools. If not something is forever crying at me.
It can charge different cell types, sizes, chemistries all at once. So when one is done just swap for another one. Individually. Every time I hear it beep I change a cell! By the end of the day everything is charged for another period.
But if you have a mix of lithium and NMH cells laying around its useful. And you can use it to est them too. So you choose test. It charges full, discharges completely and safely and then recharges full again. Leaving you with a capacity out and in in mAh for each cell. Taes a long while. But you can bin the cells that show reduced capacity. So you dont end up with a mix of knackered cells and good ones all mixed up together!
It does say that your eneloop pro cells are 85% charged after 12 months. So those ones should be OK.
https://www.panasonic.com/global/energy ... p-pro.htmlIf you look at the wiki page for eneloop you will see theres loads of eneloops, and all are a bit different. Some are good for storage even 3 years or 5 years. Some less so.
This is a good page too.
https://www.wikiwand.com/en/Nickel%E2%8 ... de_battery
