by CPguy » 21 Jan 2015, 13:29
Courtesy Google translator:
"Thoughts on driving pleasure with Segways sitting
Originally a modification of hobbyist circles, there are now many companies convert the Segways for operation in the seats and offer her product also people who are dependent on a wheelchair.
This article examines the background: the technology, the motivation and the legal environment.
A powered seated Segway is tempting for wheelchair users both sexes: appealing design and the performance can be demonstrated by practical tests. But what's behind it?
Modern technology for all!
The technology used in electric wheelchairs is described in detail in this article. A Segway contrast, uses modern and more efficient technology (eg, lithium batteries, brushless motors and a voltage of 72 volts.). Several gyroscopes keep the Segway upright and balanced. Due to the fact that the Segway has only one axis, it requires less energy to rotate and can even turn on the spot.
Price is operated in a sitting Segway with approximately € 6.000, - to 14,000, - located (only remodeling or Segway with tag) in the field of electric wheelchairs, the dimensions of approximately 65 cm x 65 cm x 65 cm (height, width , length) and weight of 60 kg are unequal advantageous.
For completeness, it should be mentioned that there a Segway-based replica control at less than € 4,000 - are, however, the technical data (lead-acid batteries with a voltage of 24 volts) so that it is unnecessary to discussion.
Ready, set, go! (or not)
Some companies (the author allows himself - without judgment and without any claim to completeness - a roll-call list, as some providers are hard to find and to draw attention to the different approaches) as "Genny Mobility" with the product "Genny" the "frankie GmbH "in collaboration with the German club" handicapped-accessible eV "products "Apache" and "Sitting Bull", the "Freee Mobility GmbH" with the product "Freee F2", the "med-i-tec GmbH" with the product "MobilityCube" the company "AddMovement" with the product "AddSeat" and the company "SegSolutions, LLC" in the US with the product "Freedom GlidR" offer sitting operated on Segways.
Safely operate these products a physical and mental fitness is required. Since steering operations with the upper body are executed some core stability is required, as well as a certain amount of manual force for transfer movements and for gripping the handlebars.
questionnaire
As mentioned manufacturers develop their products very quickly, no detailed enumeration of the respective product properties. It makes more sense, a questionnaire through which the product differences are obvious:
What is offered? If only one of provided (used) Segway rebuilt or a new Segway adapted?
How easily can the Segway are loaded? (Which is usually a ramp necessary.)
How much clearance there? (For upward and downward slopes this question is essential)
How easy is a transfer to or from the Segway? (Arm rests on the seat can be folded in making party. The handlebar is either removed or turned over.)
Position and type of Park Props? (The post may very close - for some perhaps too close, because the footprint is very small - be at the wheel, its sides or be a rod and therefore vary well in soft or uneven ground.)
Can the Segway be parked on an incline?
Can the Segway fall in the state scale of accident? (On some models it is possible to retract the supports at switched off Segway.)
Can a pressure relief be done safely? (Some models switch off when no weight is longer registered on the seat.)
Is the Segway speedlimited or not? (As with the upper body alone less weight may be relocated as standing the brake signal is not so strong, so will not be heavily braked and the braking distance will be longer.)
Does the seat and thus the focus be shifted? (For a model of the seat is mounted on a rail.)
What accessories are available? (eg light, bags, wide tires, snow tires, snow chains, etc.)
Where and how many pay load mounts are there? (Since the upper body must be moved, a backpack is usually not possible, but space for mobile phone, rain protection, money, catheters, etc. is often still necessary.)
In addition to this questionnaire is a detailed test drive - if possible, in the future application areas - makes sense.
Fun car or wheelchair?
Although in marketing materials, the manufacturer terms such as "Segway wheelchair" occur, a seat Segway is no wheelchair (wheelchairs). The rules are different in almost all EU countries: Austria In a (sitting) Segway In accordance with Austrian road traffic regulations (Highway Code) as an electric bicycle that has run on the bike or on the road. One use of the sidewalk is not allowed! Details can be found by the ÖAMTC here.
Thus, a seat Segway significantly different from one (electric) wheelchair (wheelchairs) or an electric scooter both in Austria traffic laws apply as a pedestrian.
Whether a seat Segway is a useful alternative wheelchair or a useful complement wheelchair, must therefore be decided in each individual case.
Comments and suggestions are always welcome."
So now its understandable!
