next system will use M2 memory for storage right on the MB - that makes a SSD drive feel slow - according to reviews on it
expresso wrote:i opened it up to change the paste inside - best thing i did - dropped it 30C at full load -
Burgerman wrote:Its no problem using super fast hard disk ssd as I am using a "the fastest disk in the world" apparently.
But you still need the old heavy disks for storage. Four of, 4 terabyte WD green ones here. Full. And an old SSD 2nd boot disk backup.
expresso wrote:what heat spreader ? you mean the cover on top of the chip - i didnt glue it down or anything - i just placed it on top gently and lowered the handle to lock the chip in its place .
expresso wrote:i used a normal Razor blade - the ones they use in those box cutters - working on each corner gently a little at a time - i used a small hammer to knock it in a bit and then wiggle it back and forth sideways holding the razor angled up away from the chip board -
what kind of tools do they have now to do this easier ? is this something that is do able with the AMD chips also - or is just a Intel thing ?
steves1977uk wrote:I never OC my CPU as it's fast enough at stock speeds for me. My CPU temp usually sits around 26c when just web browsing and in the mid 60c's when ripping blu-rays. I'm also a gamer as well, especially playing the Thief trilogy series and it's fan missions.
Users browsing this forum: No registered users and 36 guests
