by Mark » 02 Feb 2011, 22:17
Colin,
Sorry I haven't had time to reply before but here are my thoughts after just over three years with the lift.
Your Quote:
My concerns with this are;
1) how practicle are they
2) how reliable are they
3) what happens if there is a power cut as we get several every year
4)what would happen in the event of a fire in the night burning out the electrics
1. Very practical and very useful to everyone, not just the wheelchair user. Stairlifts are no good for a w/c user because you need two wheelchairs - one on each floor, plus two transfers each time. Our lift gets used all the time - luggage, hoover, filing cabinet, other furniture. Sometimes we wonder how people manage without a lift.
I use a manual chair in the house at present, and that is no problem. However, I can't use the F55 in the lift because when reversing out, the castors swing round and jam on the lift sides - so measure the width of your chair with both castors projecting out on opposite sides.
2. A few teething problems in first year and now reliable. Should be serviced every year and if you can't do this yourself, ask about cost of a maintenance contract. After convincing the manufacture that I was bright enough to service the lift, they agreed to let me go on their service course. In the end, possibly because they didn't want me in a wheelchair around their workshop, they actually came to my house, and we did the service course on my own lift. After this, they are happy to supply me with spares and tech support. Fortunately not needed either since.
3 and 4. My lift all works on 12V with a battery backed-up supply (12V 7Ah lead-acid sealed alarm-type battery). The mains power is only used to drive the hydaulic pump, so if the power goes off, all the lights and controls and the power door work, but you can only go down. If you get a serious fault and the system trips out, then the lift can be lowered by someone pressing a pressure release switch (mechanical) on the power pack box and this lowers the lift slowly but gently. Door can be manually opened if necessary. This would still work if a fire burnt out the electrics, but since it is all low voltage and well-designed is unlikely.
There are a number of lift manufactures to choose from. If you go to the Naidex exhibition at the NEC in April, you will see the lifts there in the flesh and can drive your wheelchair in and out of them. That's what I did to choose. When I chose there was Wessex, Pollock, and Terrys there with lifts. Not seen a list for this year's Naidex yet, but I think a new company, "Stiltz" will be demonstrating their new lift too.
I've given a presentation "Inspirational Housing Design for Easy (wheelchair) living" at Naidex NEC for the past two years but they haven't asked me this year (perhaps I'm too expensive). This explains how we did something similar to you, except we bulldozed our old house first. We wanted a bungalow, but couldn't afford the cost of the land footprint, so we've got a house with a through-floor lift. We designed it so that one of the downstairs rooms, which has a wetroom off, can double as a bedroom if the lift should seriously fail. It is normally used as my wife's (large) study and exercise room.
If you want to come and look at our house before you get too far down the process, you are welcome. We live in Derby. Google "The Tiger Moth Man" and you'll find my details.
Hope this helps,
Mark
