Burgerman wrote:Heres a few more...
CO2 in the past...
Burgerman wrote:I just had a green party member at my door. Well to be fair I grabbed her. She was leafleting... Much of what was on that leaflet was plain wrong!
So I showed her some historical records that are similar to what I posted here on various wiki pages and those all clearly showed that the warming, and the C02 were not only not significant, but were currently at very low levels. Almost the lowest in history. And that the natural temp and co2 variation was massively greater through history LONG before we had the industrial revolution. And even long before humans existed. And so anything today was barely even registering in the noise by comparison. See the pics here above for example.
Her response was typical. Ignores the facts. Not interested in knowing at all. Its the "feelings" and the idealism, thats important only. She even admitted it. They are literally brainwashed by the media. By schools. By the IPCC. And all the cherry picked graph that forms their "consensus"... Clue. Science isnt a consensus. She is convinced the world and us are under some massive threat.
And carried on posting the same garbage through the streets letterboxes. Even after I showed her why it was irrelivant. Again this is green socialism. Head in sand. Logic and reason unimportant. Only the cause matters! They really are idiots.
You might guess that she was clueless about science. Esp climate science! As most media, politicals, and warmist nuts dont actally know anything other than the "party line". No idea even of how to understand what I was showing her. No clue that carefully cherry picking just the last few years of recent history (the hocky stick graph they all run around witt) means you can make it LOOK significant even when, its actuallyjust a tiny tiny blip in the scheme of things, lost in the noise. She wasnt interested in knowing the reality - the truth. To put it into perspective. Because that ruins her narrative that she has had conditioned into her by the leftists pulling all the levers. She THINKS she knows. But cant tell me how.
She doesent understand that her leaflet is just more lefty/green propaganda to brainwash the masses. Its not fact, and its not science. And its presented as both.
Burgerman wrote:Explain?
You mean in an attempt to chat her up?
You gota be joking. She was the typical lefty. All lesbianish and covered in piercings all over her head. I wuldnt have touched her with yours.
Burgerman wrote:The Arctic and Antarctic (and highest Alpine regions) may reach a low 0.2 percent minimum - FIVE TIMES as much as the mostly natral C02.
While the warmest tropics up to 4.5 percent water vapor. Thats 112 times as much as C02.
And water vapour causes more greenhouse effect than CO2 - even if it was the same concentration. Worse, depending on if this water vapour is forming clouds or not and the altitude, it may or may not cause heat to build or be reflected or held in... And no climate models can predict this because we do not have adequate knowledge to model it properly.
Users browsing this forum: Bing [Bot] and 62 guests
