Wow! When I leave a battery charging for 16 hours it gets too hot: it burns up, and never works again: ever! Well, not when I am charging it with only 2 Amps. You must have a great battery charger.
Amps dont matter. The battery DRAWS whatever amps it wants. When presented with a voltage. The current that flows depends on internal resistance, or the limit the charger can give. Provided you only charge at the CORRECT CV voltage, and the correct FLOAT voltage at a given temperature and time limits, no damage can result.. If it warms by more than a few degrees, then you are charging at the wrong CV voltage or the battery has "run away" caused by heavy sulfation due to a crap charger...
And understand that just 0.1V too high, matters. Get this wrong, and almost every charger does, and you can easily get thermal runaway, which is what you describe.
For EG here is the CORRECT way to charge an MK Gel as used in most of our chairs.
http://www.wheelchairdriver.com/MK1.pdfIf you follow this, with an MK Gel battery for eg, which you did not, you will not get any thermal runaway. Please note that the CV voltage needs to be reduced above room temperature, and increasd below it.
Now tell me about reverse charging a battery. I've heard about it, I have seen where it has been done but I have never done it myself, and made it work.
Its the best way to ruin any battery that you will ever find. The plates are pasted with lead dioxide and lead sulphate for the opposite polarity plate. (Actually a mix of lead oxide, sulfuric acid, water, and coated with lead sulphate/lead dioxide.) Reverse charging totally screws this all up royally. Although the battery then reads 12.9V fully charged in reverse. And has a dismal unusable capacity...
My desulfating battery charger shut off automatically: I like that!
Define shuts off?
All battery charger should charge at whatever their max output amps are, till the battery reaches its exact CV voltage point, and then current naturally falls away as the battery becomes more full. This can be 6 to 12 hours typically. The charger should then stop charging at the point where current falls to approx 500th to 1000thC or 8 to 14 hours depending on spec, max, whichever is sooner. At this point it SHOULD drop to a continual float level to prevent internal losses depleting the battery over time and allowing sulfation.
It also throws error codes to help understand my battery's condition.
Besides all that, it is small enough to fit inside my chair.
Thanks for the info!
What possible error codes could it throw?
How do you set the following:
CV voltage, and the required 3mv per degree C correction for temperature?
How do you set the correct time limit, and correct termination from CV current?
How do you set the correct CV level for the float voltage?
If you cant its likely ruining your batteries.
