rlnguy wrote:I'm a bit late to reply, but one trick I have used several times, for both Phillip head, and hex head screws, like this, is to get a tube of valve grinding compound, at an auto parts store. It's like toothpaste, with carbide granules in it.
Put a little on the tip of the driver, or slot in the screw, and then unscrew normally. The carbide grit bites into the driver tip, and the screw.
I done this dozens of times, and have actually broken the tip off some pretty high quality screwdrivers-but they didn't slip out of the screw..........
good luck
good luck
Burgerman wrote:I think it should be test flown. And videoed.
rustyjames wrote:I've had success in the past using a hand held impact driver with the appropriate bit. https://www.zoro.com/proto-impact-drive ... gK93_D_BwE
Burgerman wrote:You only live once.
Send it back, get one of these:
http://www.1000espressos.com/images/mac ... A%20XL.jpg
expresso wrote:rlnguy wrote:I'm a bit late to reply, but one trick I have used several times, for both Phillip head, and hex head screws, like this, is to get a tube of valve grinding compound, at an auto parts store. It's like toothpaste, with carbide granules in it.
good luck
like this one ? would i have to mix it with water or just use it as is ?
https://www.amazon.com/Permatex-80037-V ... B000HBM80M
motoman wrote:expresso wrote:rlnguy wrote:I'm a bit late to reply, but one trick I have used several times, for both Phillip head, and hex head screws, like this, is to get a tube of valve grinding compound, at an auto parts store. It's like toothpaste, with carbide granules in it.
good luck
Yup thats the stuff, use right out of the tube. It will give you a little more purchase on the screw.
Burgerman wrote:Real thing?
Yes for many years we do a row of them on the bar after and have one or 3 each! The beans get roasted but are bitter, and the drink is sweet and gets warmed up so matches it.
Burgerman wrote:After , tends to make you sleep well after the 3rd or 4th one too.
Users browsing this forum: No registered users and 24 guests
