You can set it as a 3 stage charger, with precise settings for MK,
I think you should order the one from shirley, as its ADJUSTABLE voltage which is useful, way more power, already converted, and is also a server supply. And a 3 stage charger! Those are $60 and we already know are good. Right now theres no comparison. Get them while you can.
https://www.wheelchairdriver.com/board/download/file.php?id=7796&t=1
Yes but you wont understand it.
Yes...
So much worry, so little time! Sometimes you just have to accept a risk, and go with the flow!
No.
Weld? = solder. Still no.
Unless you order the fancy case, and then much assembly! And yes.
Also allows you to set a CC/CV charge setting too, with a termination you choose so can auto charge a battery if you want with no charger needed.
There are 3 threads on the main part of the forum. One explains how to work it! Have a read. Its actually quite easy, but initially looks complex. You soon get used to it.
Heres 1 thread... viewtopic.php?f=2&t=7670&start=60
martin007 wrote:
I'm a man with bad luck ...
What exactly are you getting this PSU for ?
Any special applications ?
