Burgerman wrote:Is it true that there are actually 4 wires. Phase 1, phase 2, and neutral and earth in the wall behind a 110 volt outlet?
Irving wrote:@expresso, don't get too despondent, they do exist. McMaster do the right sort, just not big enough. https://www.mcmaster.com/70245k85
But whoever makes these probably makes bigger ones.
expresso wrote:my thinking is if the AC is asking for 115V - the outlet will only supply whats asked ? or would it burn it up - blow the AC unit ?
Irving wrote:Don't search for 220 to 115 cos the actual conversion is 220 to 110. Search on something like "220v step down transformer"
Burgerman wrote:Also call the air con manufacturer. Some items can be swapped over to 220/240V or 110/115 as many things get sold worldwide. To make something that is 110 only limits their market to the US alone. there may be an easy way to convert both ways.
foghornleghorn wrote:Would an alternative be to plug the AC into a normal socket, and charge the chairs from the 220v socket with a different power supply for the PL8?
Users browsing this forum: No registered users and 28 guests
