Burgerman wrote:For e.g. I just added my signiture to the bottom of this chinese lithium battery PDF adobe document.
Burgerman wrote:Yep. But low res.
Signitures dont matter. I often sign cheques D. Duck, they still go through.
But you are right. I will remove it!
Burgerman wrote:Right up till it fails.
https://www.moneysavingexpert.com/banki ... -complain/
Have a read. Caused me nothing short of a month of hell. A box of cash hidden away for emergencies always works. I recommend it!
LROBBINS wrote:Essentially do it many times each month. Just copy the sig to an image file (jpg or other), then use the sign tool in adobe reader to insert that files as your signature in the new document.
Burgerman wrote:I just added 1 page and 1 link, and 1 image to this in under 1 minute...
I opened the PDF with word, added the extra stuff,on an extra page and resaved it as a PDF file...
Burgerman wrote:And what stops you?
This baffles me.
>>>i have a Signature -
Is this a jpg. a gif, or do you have it copied to the clipboard? If so from where?
>>>i want to copy it exactly the same way and paste it in another blank doc.
Is this an image? How are you copying that? If its an image you can select it, copy and then paste into a new place, page, or document. If its a part of an image, do a screen shot, and open in an image edditing suite like photoshop or whatever, and select the AREA you want, copy to clip, paste into word. Or save as an image on your desktop.
Burgerman wrote:So you changed an image to an adobe pdf? Why?
You needed to open the image in photoshop, or similar, select the bit you need, then save that as a new image called signiture.gif or .jpg.
NOW you can past that into any word document or post it up here...
You got everything back asswards. Your PDF file is just a single image.
steves1977uk wrote:expresso, try this small program which scans documents as a PDF file... https://www.softwareok.com/?seite=Microsoft/WinScan2PDF
Burgerman wrote:Scan and save blank and original forms as .gif files. And they will be small. Email them to me and I will do it for you... It will be way quicker!
