The dangers of anti muslim racism
Re: The dangers of anti muslim racism
Postby Burgerman » 13 Nov 2020, 20:31
OK, I'll address the rest later but in the meantime let's try a little thought experiment.
Suppose that artificial intelligence research has succeeded in constructing a computer that behaves as if it understands Chinese. It takes Chinese characters as input and, by following the instructions of a computer program, produces other Chinese characters, which it presents as output.
Suppose that this computer performs its task so convincingly that it comfortably passes the Turing test: it convinces a human Chinese speaker that the program is itself a live Chinese speaker. To all of the questions that the person asks, it makes appropriate responses, such that any Chinese speaker would be convinced that they are talking to another Chinese-speaking human being.
Does the machine literally "understand" Chinese? Or is it merely simulating the ability to understand Chinese?
It doesent understand anything. Its way way too simple, is doing serial calculations, and has no consousness. Its absolutely capable of responding correctly. Thats not thought. or consiousness. Its programmed to do as instructed. Even if it can learn and add to that program. We need to tell it how. And its still not a neural network so will never be consious. To be consious, and so "undestand" meaning etc requires a parallel system. A neural network. Just as used by insects that are currently being copied in a limited way. Although too simple so far.
Suppose, for example, that I am put in a closed room that contains an English version of the computer program, along with sufficient papers, pencils, erasers, and filing cabinets. I could receive Chinese characters through a slot in the door, process them according to the book's instructions, and produce hand-drawn Chinese characters as output. If the computer had passed the Turing test this way, it follows, that I would do so as well, simply by shuffling Chinese symbols and following instructions in English manually.
There is no essential difference between the roles of the computer and myself in the experiment. Each simply follows a program, step-by-step, producing a behavior which is then interpreted by the user as demonstrating intelligent conversation. However, I would not be able to understand the conversation. I don't speak a word of Chinese, Therefore, it follows that the computer would not be able to understand the conversation either.
Correct. But you are aware of doing it.And can change things, refuse, and are self aware. A serial computer never will be. My desktop has 4 cores. That is like a brain consisting of 8 neuons. And no AI software. Even a fruit fly has 100,000 cores! And each core has its own memory. And each core connects to maybe 5k of the others. We are nowhere near this.
Without "understanding," or biological, life-based, volitional "intentionality", we cannot describe what the machine is doing as "thinking" and, since it does not think, it does not have a "mind" in anything like the normal sense of the word.
Correct. Its a calculator.
Your argument is logically fallacious because it relies on a non-hierarchical use of concepts i.e. it's as if someone were discussing the architecture of a penthouse while denying the existence of basements and ground floors and staircases. But ground floors and basements are essential to an understanding of the concept of "penthouse."
The concept "penthouse" has no meaning independently of those less abstract concepts any more than the concept "thinking" has a meaning independently of life, free will and consciousness.
Here we go again. You have gone off the rails with all your big words and think they can achieve something. I read it 6 times and its word soup.
We already know that something that is processing info in the way our serial computers do cant ever understand or be consious. Thats why we are starting to clone the neural networks in insects. They have already done this for super simple creatures. A 100k brain cells in a fruit fly in a massively interlinked neural network, can absolutely learn. And make the fruit fly behave as it does. And it probably has an extremely dull and limited level of consiousness. But its too simple as a neural network to be a maths genius. It can likey detect and go towards the light or the smell of its food for e.g. Mostly its 99.99% simple algorythms. It runs along without free will just as you do. It is basically Ai in the same way we are developng computers that are. It likely doesent have enough cells to really understand anything. Certainly not enough for its brain to develop a model of the world internally to present to it as a map of reality as yours does. Thats your awareness.
You are using the word "thinking" independently of its essential roots. You are literally "stealing" meaning away from its necessary context.
I dont give a fig about your infatuation with words. They do not matter. What matters is whats true. This is why philosophers and philosophy are a waste of time. You think playing with the meanings of words and stuff is important. They are not. I dont care words are just labels.
I dont care about your definition or about words or your heroes from yesteryear in the time of ignorance. Only the reality of what is true. We will eventually make a full 100k neural network. We are 10% there now. And it makes machines behave like a fruitfly. With NO programming. The next job is to up that neural network 10, 100, a million times on a chip. Not a serial chip. One where every transistor can talk to many of the rest simultaniously. Just like your brain. A network. A parallel network. At this point we will have copied the fruitfly brain. And if it has all the same input sensors, such as eyes, taste, smell, gyros for stable flight or whatever sensors it uses, muscles, temp sensors etc then it could be said that it too has a tiny spark of consiousness. If not then we will multiply that until it can like a baby program itself, and develop a level of thinking and consiousness of maybe a mouse. But moors lay says we will get there much much faster than you expect. Give it a decade.
The “stolen concept” fallacy, first identified by Ayn Rand, is the fallacy of using a concept while denying the validity of its genetic roots, i.e., of an earlier concept(s) on which it logically depends.
Thats all indistinct bullshit. ahts a stolen concept? Dont tell me I dont care. What "genetic roots"? Again, dont answer, I dont care. Who cares what she thinks. Who cares about words. Who cares about what philosophers "think" they understand practically nothing in this world today. Try to unlearn all that ancient wordplay garbage and follow the SCIENCE!!!
Postby Burgerman » 01 Dec 2020, 17:33
https://www.express.co.uk/news/world/13 ... ate-terror
Some more of that "racism" for you. Muslims should not have been allowed to destroy europe. Blame the EU and their "values"... The police are looking for a motive. Poice tha are that stupid should be fired.
Because obviously this range rover driven at speed across children, teenagers, and mothers with many dead and dozenz injured was obviously a muslim. Even if they wont say it. A 51 year old man...
Postby Burgerman » 01 Dec 2020, 23:26
The police say they think it was "mental illness" again... They cant find the motive! :clap
Postby Burgerman » 02 Dec 2020, 15:17
And another one next day in brussels.. Several stabbed by a "tinted" man about 30... They since removed the term tinted. But we al know exactly what this all means. Police cant find a motive for the snack bar attack. Half the comments (not closed!) mention the tint...
Marvelous all this right wing - sorry I mean muslim multiculturaly enhanced death, blood and suffering is. Isnt it. banghead
Postby Lord Chatterley » 04 Dec 2020, 06:24
Total victim numbers are appalling - so much for the gratitude for the 'refugees welcome' mantra.
youtu.be/o8-OtyUb9ok
LC
Lord Chatterley
Postby Lord Chatterley » 04 Dec 2020, 18:00
Radicalised asylum seekers have murdered or injured more than 1,000 people in terror attacks in Europe since 2014, a new report has revealed.
In the past four years, 32 Islamist plots have involved those who had sought sanctuary – or 16 per cent. Three of the potential atrocities were in the UK, including Parson Green tube bomber Ahmed Hassan.
An analysis by academics found 44 refugees had either carried out atrocities or been thwarted before they could bring bloodshed to the streets.
https://www.dailymail.co.uk/news/article-5849611/Radicalised-asylum-seekers-murdered-injured-1-000-terror-attacks-2014.html
LC
Lord Chatterley
Postby Burgerman » 04 Dec 2020, 20:04
Cant be right. Redder says its a right wing problem. And that anyone with a dislike of muslims is racist. Redder, what "race" is a muslim???
Another direct question that he will ignore.
Postby Lord Chatterley » 04 Dec 2020, 21:55
Burgerman wrote:Cant be right. Redder says its a right wing problem. And that anyone with a dislike of muslims is racist. Redder, what "race" is a muslim???
He may choose to ignore it and that is his right but this is a public discussion and those who are not directly involved will be making up their own minds.
That's how societies improve - not by laws or censorship but by free thinking, making mistakes, and learning from those mistakes.
LC
Lord Chatterley
Postby Burgerman » 04 Dec 2020, 22:12
The whole thread title is already a self contradition...
Postby Lord Chatterley » 05 Dec 2020, 18:29
Burgerman wrote:The whole thread title is already a self contradition...
True. I don't think it's entirely caused by moral cowardice though.
LC
Lord Chatterley
Postby Burgerman » 05 Dec 2020, 19:44
No its how the left think. They want to control what society sees as right. Right being how they think. So any kind of reasoned rational argument on any subject at all that they disagree with is shut down. Anything to the right of the extreme left wing guardian and you are hitler. Anything about muslims and you are either a "racist" (and muslim isnt a race) or you are an "islamaphobe"... A phobia is an irrational fear. And theres nothing irrational about it. They want you dead and certainly do attack and kill you.
Its just a way to shut down any reasonable discussion that they disagree with. So your opinion is always "disallowed" or "wrong"... This is the whole of the social media, search results, TV and magazines, schools, colleges, universities, and the political left. Its because they all want freedom of speech as long as its their speech. So for e.g. according to the BBC and all of the lefty media BLM is all marvelous! Even though its a political anti capitalist, extreme left movement. That commits all kinds of violence and damage. If you object, you are "racist"...
Postby Lord Chatterley » 05 Dec 2020, 21:24
Just watching Sky Arts Auction TV series - must be a repeat because the featured Christies' auction at Hotel Dieu, Beaune, hangs in the balance due to a terror attack in Paris. No mention of who or why the terrorists committed the "shootings". They decide to go ahead after a minutes' silence then sing the National Anthem - the first time they have done that before an auction since the liberation of France during WW2.
There's no escape from the endless drip, drip, drip...
LC
Lord Chatterley
Postby Burgerman » 06 Dec 2020, 12:51
You realise that the media bias, the endless drip drp drip, the fake news stuff, adverts, and any kind of government, politcaly correct garbage, global warming and green stuff, or socialism, or woke garbage, multiculturalism,etc only works on the dumb masses especially the ones that think they are "educated"...
Those with some real intelligence just see it for what it is. And by intelligence I mean TRUE intelligence, IQ and a litte worldwise experience. The true skeptics. Those that dont believe stuff just because someone tells them its true. Not some college educated degree or PHD or worse. They tend to know a lot about some narrow feild. But seem as gullible as hell.
Postby Burgerman » 07 Dec 2020, 18:00
Remember the french schoolteacher that had his head cut off in the street by a guy shouting alans snackbar?
The one where the police couldnt find a motive?
Well they just buried him with all his muslim townfolk celebtating him as the lion of islam
Footage from this weekend shows mourners at the funeral of 18-year-old Abdullakh Anzorov - in his native village of Shalazi in Russia. Around 200 people attended the Muslim funeral in freezing weather conditions, with BAZA Media reporting Anzorov had been buried "with honours". Video footage showed mourners chanting 'Allahu Akbar', meaning 'God is great', as they walked alongside his coffin.
Several clips were shared across a number of online platforms, with one carrying a message lauding him as "The Lion of Islam".
A message with the video read: "The Lion of Islam has arrived to native soil today, and returned to the soil. No-one but Allah has strength and power."
The killer, whose body had been returned from France on Saturday, was carried through the village by mourners in Urus-Martanovsky district.
Dozens of police sealed off the entrances to the tiny village of Shalazi to stop other people attending the funeral.
Yes redder, the problem is obviously the right. :clap
https://www.express.co.uk/news/world/13 ... ty-killing
Postby Burgerman » 11 Dec 2020, 15:53
A bit more of that massive problem, the dangers of right wing racists.
Sorry I meant muslim stabists and murderers...
AT LEAST three people have been injured in a mass stabbing attack at a shopping centre in Germany, according to local reports.
https://www.express.co.uk/news/world/13 ... ars-latest
AT LEAST two people have been injured following a stabbing spree in a shop in the centre of The Hague.
https://www.express.co.uk/news/world/13 ... arktstraat
SEVERAL people have died and many others have been injured after a car ploughed through pedestrians in Germany.
And theres a couple more in germany, and two in the UK.
https://www.express.co.uk/news/uk/13673 ... nife-crime
And more.
MASSIVE problem this right wing racism...
Return to Anything
Users browsing this forum: No registered users and 33 guests
