Burgerman wrote:>>>soft pack Li-Ion
Or polymer? 7S
Or LiFePO4? 8S
All available as soft packs. Either way it doesn't much matter as you can use whatever you want.
Burgerman wrote:Ooh. Lovely. Those go off better than fireworks if faulty, overcharged, charged while unbalanced, punctured or damaged, or if they swell with age. And they have a very short cycle life.
Heres one going off for no particular reason. https://www.youtube.com/watch?v=k9mcNvOGKtI Turn volume low.
motorcycle jack wrote:Gimpy -
A couple of things you mentioned - first, the clip is aluminum not plastic. I carry a pair of lock jaw pliers, clamp on the clip and pull. The added leverage works enough to unhook the clip.
John
MenCallMeGimpy wrote:motorcycle jack wrote:Gimpy -
John
One question: have you found that the folding stiffness eases up over time? To be honest, I've only folded and unfolded it a couple of times so far, so it's still "factory fresh," but I'd like to be able to set the thing up unassisted.
Burgerman wrote:Take apart. Give rubber part a wipe to make sure its grease free. Its supposed to conduct. And clean the traces it contacts with a green scotchbright cloth carefully. Reassemble and it should be as good as new.
Robert Pollock wrote:Hello all,
Great finding this forum. I live in London, UK and I am thinking of buying a Foldawheel PW-999UL. I see that it has had very positive reviews, however:
1 - The posts about false copies on Amaxon worry me, if I am going to spend £2,000 GBP I want to be sure I am not swindled.
2 - The post about the battery on that model plane blowing up worries me.
3 - Being in London, if anything went wrong with it I need to be sure that I can locate help.
I would appreciate your input very much.
Regards
Robert Pollock
Sportingmac wrote:FYI. Just had a chat with Shirley (Wheelchair88 Marketing lead) and she informs me that they do sell through Amazon in UK - VAT free if a Blue Badge number is supplied at time of order. (details available on Amazon links) Prices shown are VAT free prices btw.
You might want to check with Shirley directly if the same applies in the US and elswhere.
