Hi Guys
I really don't care what people on forums say about me and my abilities or lack of abilities, but when it comes to the highly competent programmers who help me out, I do feel honour bound to defend them against unjust comments written about them on this forum or anywhere else, That's only being fair and decent. Isn't it? So if anyone who reads this is guilty of such unjust commentary, kindly read what follows. (Its an email from one of my programmers):
_________________________
This is a hardware export from the the PowerLab 8v2 battery charger. The way to use it is to import the file .. the following link explains how to do that on page 50 of the pdf. I suggest you export the current presets before importing the one you have been given, then if anything goes wrong you can simply import your original setup back again.
http://www.revolectrix.com/support_docs/item_1437.pdfThe contents of the attached 'BM-Presets.PS8' file are plain text and not user editable as the hardware expects to read the data in a prescribed format, but I have copied and pasted it below for you to see what it actually consists of,
rgds,
T.
// Preset File Created on 02-04-2019 at 18:49:45 for the PowerLab 8v2
// SAFETY HAZARD: Do not edit this file directly. Changing any of the
// data will cause the preset to loose its validation and cause it
// not to run on the PowerLab 8v2.
// ONLY USE THE Charge control software to edit the preset.
// Preset 1
//LCD: LiFe use this Set16.0A BAL 0Cy
//ID: 000000000
//DateTime: -8586523007002126382
//Description:
//BattBrand:
//UserName:
// LiFe` use this `
DW 0000110000000001b //0
DW 0000000011000011b //1
DW 0111010100100000b //2
DW 0110010101110011b //3
DW 0111010000100000b //4
DW 0110100101101000b //5
DW 0010000001110011b //6
DW 0010000000100000b //7
DW 0010000000100000b //8
DW 0010000000100000b //9
DW 0010000000100000b //10
DW 0010000000100000b //11
DW 0010000000100000b //12
DW 0010000000100000b //13
DW 0010000000100000b //14
DW 0010000000100000b //15
DW 1001111101000001b //16
DW 1010011011010000b //17
DW 0111111111111111b //18
DW 1000110100000011b //19
DW 0001110001000101b //20
DW 0001100010010101b //21
DW 0110010001011010b //22
DW 0000000000110100b //23
DW 0001010010001000b //24
DW 0101001000111000b //25
DW 1111100011111111b //26
DW 1111001001111010b //27
DW 0000000010010000b //28
DW 1111101001000001b //29
DW 0000101001101101b //30
DW 0000101101011100b //31
DW 0000101110001101b //32
DW 0000101110101011b //33
DW 0000101110110100b //34
DW 0000101110111011b //35
DW 0000101111000110b //36
DW 0000101111010011b //37
DW 0000101111011100b //38
DW 0000101111101011b //39
DW 0000110010100111b //40
DW 0100010000000000b //41
DW 0011001100010000b //42
DW 0110000000000000b //43
DW 1110000010000110b //44
DW 0001010001010111b //45
DW 0001001111100000b //46
DW 0000000000000000b //47
DW 0001010010000000b //48
DW 0100100010000000b //49
DW 1110110010101000b //50
______________________________________________
