Burgerman wrote:HERES A FEW MORE OF MY LEAD PRESETS.
One for XLR connected and MKs limited to 12A max and safe on any chair. (Change volts to 28.80 for AGM or 29.4 for Odyssey/Optima.)
One for charging MK at high amps in series.
One for charging MK at high amps in parallel.
One for charging MK at high amps ONE MK battery.
One for charging Odyssey at high amps ONE battery (and if you reduce volts to 14.4 any AGM deep cycle sealed battery)
One for charging Odyssey at high amps in series 24V
One for charging Odyssey at high amps in parallel at 12V
This IS a zip!
Burgerman wrote:Dont use parallel packs. It does funny things...
To charge gel via the XLR you need this REMOVE.ZIP:
Wheelchair services have given me two cheap AGM batteries for my Sunrise Salsa chair. I think in the past the batteries were gel?
Is there a PL8 preset for a single 55Ah AGM battery?
And for two AGM batteries through the XLR port on the chair.
And for a single Gel battery while I'm at it.
Does the supplied 8AMP charger even do AGM?
Burgerman wrote:So you want a stand along charge profile for
1 x 12V battery GEL, say 30A?
1 X 12V battery AGM, say 20A?
And 2x AGM 24V but limited to a 12A max to be safe on XLR charge connections on stock chairs.
If correct I will upload later.
Users browsing this forum: No registered users and 39 guests
