FOR SALE A CUSTOMISED QUICKIE F55 POWERCHAIR
Postby lambchops83 » 12 Apr 2016, 10:48
This customised power chair is now being sold with many spare
Parts including loads of high tension nuts and bolts that were used when it was rebuilt as the whole chair was needing a re- powdercoat in black gloss, as some parts had not been done to my specification and has many new parts now fitted, this power chair has had very little use , whilst the quickie stays in its lock up storeage container and on triclecharge for most of the time although the batteries are one hundred percent tested just recently, they are two 80ah heavy duty agm batteries with the four pole motors of amd 13kph for true in side and outside use and even off road for higher speeds with the comfort of getting up any steep hills without any drop in power what so ever, this powerchair is superb for any type of work there is no other contender that will match this powerchair ,the powerchair is a slight copy of the bugermans powerchairs but could be much more powerfull if you wanted higher speeds than what it has already with more specifications to make it go even faster.
The powerchair at the moment has its standard wheels fitted but has the wide wheels included with three pairs of hubs and spacers for outside and off road use the chair size at the moment is 18 x 18 in width and depth but this can be altered for your personal size by yourself as the chair is so easy to alter, for your comfort, with a rehab seating, and head rest not fitted but included central folding adjustable footplate of which it’s powered in/out/up and down for leg comfort, with back pads not fitted but included the main seat tilts backwards for more added comfort it has the r-net 120a control system with on board an isolation switch for any type of electrical problems whilst in use this pops out and turns off all power to the system, all tyres are puncture proof with sealant in all inner tubes, this also comes with a mains charger in the sale price the power chair stands me in at over £9,000.00. but i do not expect to get that sort of money back on this custom built f55 quickie but i need a reasonable offer to seal the sale of this power chair you can contact me on my email address at tel.eve247@gmail.com only people who are genuinely interested need to apply to this add, no time wasters please thank you..
lambchops83
lambchops83
Re: FOR SALE A CUSTOMISED QUICKIE F55 POWERCHAIR
Postby lambchops83 » 12 Apr 2016, 11:02
quickie
forgot to add , so here is a couple of pictures
lambchops83
Postby rover220 » 12 Apr 2016, 12:23
Good looking chair.
Postby lambchops83 » 05 Oct 2017, 17:47
This chair is still for sale I will accept offers in the region of £4,500
if more pictures are required please message me
lambchops83
Postby CPguy » 21 Oct 2017, 20:10
Could you please post the exact dimentions as well as seat and backrest size?
My rides:
2 Progeo YOGA (for traveling)
CPguy
Postby Burgerman » 21 Oct 2017, 20:29
Which footrest is that?
Postby hank » 21 Oct 2017, 22:03
Burgerman wrote:Which footrest is that?
Looks like this one John if helps.
https://www.quickie-wheelchairs.com/rep ... -footplate
Postby Burgerman » 21 Oct 2017, 22:16
Thanks. Yes from a pulse.
Postby hank » 21 Oct 2017, 22:41
:thumbup:
Postby lambchops83 » 03 Nov 2017, 15:44
CPguy wrote:Could you please post the exact dimentions as well as seat and backrest size?
Hello CPGuy
Sorry about the amount of time it's taken to get you these dimensions through to you the power is 38 inches in length including foot plate folded in, it is 17 inches high without seat or arms attached and 22 and one half inches wide the seat is a Jay soft combi it's 20 x 20 inches the rear seat is also 20 X 20 inches regards lambchops
lambchops83
