rover220 wrote:Do you have the hasp key/dongle?
anubis801 wrote:Finished!
I got 10 PCB's left over, if anyone is interested in a bare PCB send me a PM.
...Meaning the data pin of the controller.The voltage output at the signal pin is 9.8v according to my meter ... this is a Serial level voltage not TTL.
woodygb wrote:The voltage output at the signal pin is 9.8v according to my meter ... this is a Serial level voltage not TTL.
void setup() {
Serial.begin(9600);
delay(300);
void loop() {
Serial.write(248);
Serial.write(134);
delay(11);
Serial.write(254);
Serial.write(248);
Serial.write(230);
Serial.write(128);
Serial.write(152);
Serial.write(128);
delay(229);
The SBL wire is pulled up to 5V with a 270 ohm resistor, through a diode. This is the recessive state and it represents a 1. In the
dominant state, the SBL wire is pulled down to 0V, and this represents a 0. Note that the transmitting circuit will not achieve 0V;
1V is more likely.
Of course, the recessive and dominant states are simultaneous on both wires.
To summarise:
The recessive state is typically represented by SBH = 0V, SBL = 5V. The recessive noise margin is 5V, and impedance
(oversimplified) is 135 ohms.
The dominant state is typically represented by SBH = 4V, SBL = 1V. The dominant noise margin is 3V, and impedance
(oversimplified) is 15 ohms.
jagodo wrote:I'm having trouble with connecting a Rhino2 to a DX-HHC that I just bought off ebay. So I tried buzzing the connections and couldn't make sense of the results until I discovered that the DWIZ-ADAPT has active components within it, presumably these are level shifters to reduce the 24V connections to a safe level. The DX-HHC works but says that the chair isn't powered, so I guess I have been sold a broken unit or DWIZ-ADAPT.
The RHINO2 programming adapter will plug directly into an off-board charger socket or into the 4-pin Molex Mini-Fit Junior connector with the use of the AMP programming adapter.
rover220 wrote:You normally have to connect directly to the 4 pin molex via the DWIZ-ADAPT
jagodo wrote:rover220 wrote:You normally have to connect directly to the 4 pin molex via the DWIZ-ADAPT
So my issue is probably just having a blue adaptor instead of an orange one?
gcebiker wrote:Cheapest way to get an adapter is to make up one of the board i linked to above, you will still need a USB - RS232 and the software but they are the easy parts.
gcebiker wrote:Or drop it into a shop to get it tweaked, money well spent getting little jobs like this done professionally...if its likely to be your only need for the tools.
gcebiker wrote:... and the software but they are the easy parts....
woodygb wrote:Communication success with RHINO controller. ....NO dongle ..NO DWIZ-ADAPT ...NO board ...comms via cheap CH340 chip USB -SERIAL Adapter
e.g. http://www.ebay.co.uk/itm/NEW-USB2-0-TO ... SwuAVWx9ih
This adapter MUST use a win chip head CH340/341 or HL340 NOT a Prolific chip.
You will see 340 embossed on the RS232 end of the cable.
Wizard snapshot.
Users browsing this forum: shirley_hkg and 34 guests
