NORTH BILLERICA, MA, US 05/16/2017 5:42 P.M. Delivered
Chelmsford, MA, United States 05/16/2017 2:32 A.M. Out For Delivery
Chelmsford, MA, United States 05/15/2017 11:34 P.M. Destination Scan
05/15/2017 9:40 P.M. Arrival Scan
Baldwin Park, CA, United States 05/11/2017 12:30 A.M. Departure Scan
United States 05/03/2017 7:00 A.M. (ET) Order Processed: Ready for UPS
I think I have the charger set up right - I'm currently bulk charging the cells 4 at a time in parallel, using a jig I made (more on that later)
I'm charging to 3.6V nominally, the display keeps flipping between 3.599 and 3.601V... I set the memory to 60,000mAh (4 x 15000) and the maximum charge rate to 20A - but the display seems to show a max rate of about 3.5A which falls off rapidly.
So far the charge reached '100%' in about 35 minutes, but I let the batteries soak for a little over 2 hours, when the charge current display is around 0.050mA... Is this a good stopping point?
I noticed the Ri value seems to start around 50 mOhms, but seems to go up to about 70-75 as the charge goes up... Is this normal?
Burgerman wrote:Not really on 1S.
LROBBINS wrote:The core of Rachele's speech output computer is a nearly 10,000 line set of PerfectScript macros and what she sees on screen is several hundred tables in a WordPerfect document. I challenge any Word expert (or OpenOffice expert for that matter) to reproduce even 10% of what we've been able to do with WordPerfect - and I'll even give you a copy of the source code to help you get started. My guess is that just trying to create two different-sized tables on successive pages, then edit the first one without screwing up the second, will prove to be a disaster.
So to clarify, when I am looking at the balance connectors on the charger, is the most negative pin on the right?
And the most positive pin on the left?
Users browsing this forum: Bing [Bot], shirley_hkg and 33 guests
