Rebuild BM2 green...
Re: Rebuild BM2 green...
Postby Burgerman » 15 Dec 2016, 00:56
No BM2 rebuild. But will do something similar for that. But invacare do a centre plate as special order so may do that. At silly £££
Postby Burgerman » 15 Dec 2016, 00:57
Have to add, DOMESTIC oven, thick or 2 coats, and set to 80C. Or the wrinkles don't... But once you use this stuff a few times you get how it works. Leaves a very hard to damage grippy black finish.
Postby hank » 15 Dec 2016, 10:01
Burgerman wrote:No BM2 rebuild. But will do something similar for that. But invacare do a centre plate as special order so may do that. At silly £££
Nice one.
Finish looks well on the footplate.
Is it a heavy footplate John
What is it made of cast alloy.
Foldawheel PW 1000 XL.
Postby Burgerman » 15 Dec 2016, 10:03
Its heavier than my usual home made ones. Yes cast.
Postby hank » 15 Dec 2016, 10:04
Cheers
Postby Burgerman » 15 Dec 2016, 12:36
My only real concerns with it are that its a little wider at the rear than my custom made ones are. It may limit how far back it will be able to go. Without changing to 8 inch casters which I would rather avoid. We will see.
Its strong, the holes allow water etc to drain and not puddle as it does on my flat plate ones. And the extra weight low down isnt a bad thing on a lithium chair as they need it.
Postby ex-Gooserider » 27 Dec 2016, 05:12
Only problem with cast is that it can be brittle... I had several footplates on the swing-aways I use on the Jazzy shatter when I hit stuff... Looks like they were made from cast aluminum or something similar as it was non-ferrous.... replacement footplates made in AA welding shop out of tubing and steel plate, no more problems with bending or shattering....
The center plate on the Invacare I'm rebuilding is currently solid, but my plan is for it to spend some time on the CNC mill getting lightened by the addition of some judicious hole and slot patterns.... I'd think you could do something similar with your home built plates and a drill press.... Slots would be hard, but holes are easy, just make a template on the computer, (CAD package) print, tape to plate and center punch holes, then drill and countersink...
For a one off, it will probably take me longer to do it on the CNC between the time needed for programming, and doing the setup, but it will let me do more of a fancy design....
Postby Burgerman » 19 Feb 2017, 23:45
Bump... So I don't lose it.
Postby ex-Gooserider » 21 Feb 2017, 04:39
Burgerman wrote:Bump... So I don't lose it.
I thought it was big enough that you'd risk tripping over it..... :P :lol:
Postby Burgerman » 21 Feb 2017, 10:26
Well I dont walk, so cant.
Postby FourLions » 16 Jul 2017, 23:51
Hows the BM2 going along John ?
Loving my Quickie F55s every day i use it :)
FourLions
Postby Burgerman » 17 Jul 2017, 00:26
I dismantled two of them, worn out. I am building a green version with lithium, and 130/60-10 tyres/wheels. But lack time and a carer that can help right now.
Postby FourLions » 17 Jul 2017, 09:35
You will get if finished and will be very high quality work my friend :)
FourLions
Postby hotwheels_75 » 19 Jul 2017, 23:10
Burgerman wrote:Tidied up...
Curious, does that one connector mean only one charger is needed? Or still two PL8s? I read through but didn't see anything that mentioned it. I read in other posts that you recommend two. I've been searching online for them, preparing for my possible lithium upgrade. I assume PL8 is PowerLabs 8? That's what I see here when searching.
hotwheels_75
Postby Burgerman » 20 Jul 2017, 00:23
The PL8 is a 8S charger. 8S is 24V. So one charger, one cable.
I buy here:
http://www.store.revolectrix.com/Produc ... Lab-8_2366
Its best to get a charger, a USB adapter, a 36 inch 8s extension, etc at the same time. Because of shipping.
Postby shirley_hkg » 04 Dec 2017, 08:30
banghead
Postby Burgerman » 04 Dec 2017, 11:18
Why banging head?
Postby shirley_hkg » 04 Dec 2017, 11:38
Can't upload photos .
Postby steves1977uk » 04 Dec 2017, 12:25
You'll be going czy if you keep banghead Shirley :mrgreen:
Postby greybeard » 04 Dec 2017, 16:30
shirley_hkg wrote:Can't upload photos .
Same here.
Postby Burgerman » 04 Dec 2017, 17:49
TEST
It may be that I was doing a backup of the forum at the time, and I do this every 2 or 3 days for an hour or two.
Postby shirley_hkg » 05 Dec 2017, 03:08
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, webmaster@wheelchairdriver.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
Postby Burgerman » 05 Dec 2017, 07:36
Yes that sounds like it may be me murdering the server at max speed for 2 hours downloading backups. It shouldnt be someone else as its all load balanced / cloud etc. But I can use 100 percent for a long time.
Postby Lord Chatterley » 23 Feb 2018, 04:31
Burgerman wrote:The PL8 is a 8S charger. 8S is 24V. So one charger, one cable.
I buy here:
Does bluetooth come as standard on the dual PL8?
LC
Lord Chatterley
Postby Burgerman » 23 Feb 2018, 05:15
Its on the newer carbon looking ones with bump controllers. But theres no pc software as of yet. And we dont know if its got all the lithium/lead charge choices, or has been safety nazi'd regarding voltages, cell balance levels, time limited on CV or total charge, etc etc.
Postby Lord Chatterley » 23 Feb 2018, 17:49
Burgerman wrote:Its on the newer carbon looking ones with bump controllers. But theres no pc software as of yet. And we dont know if its got all the lithium/lead charge choices, or has been safety nazi'd regarding voltages, cell balance levels, time limited on CV or total charge, etc etc.
So USB only on the PL8x2 ?
LC
Lord Chatterley
Postby Burgerman » 23 Feb 2018, 18:18
Officially, but at least its opto isolated.
Postby Lord Chatterley » 23 Feb 2018, 22:36
Thanks.
LC
Lord Chatterley
Users browsing this forum: duke1, Google [Bot], hank, peterik, rickystyx, shirley_hkg, Vitolds and 47 guests
