Burgerman wrote:Well only you are in the position of being able to figure out whats wrong as you have the chair. But it will be one of the above!
Burgerman wrote:Wouldnt that make tilt easier (less amps)?
rover220 wrote:Burgerman wrote:Wouldnt that make tilt easier (less amps)?
I've had a few pints and can't compute but I'd put money on the amp limit needing lifting. See it often.
Burgerman wrote:That may be it. But I think alcohol may have confused. Sitting further back would either make no difference or reduce the effort (amps) needed to tilt. Depending on exactly what you moved. So its still worth looking very carefully at things. Does it work without you in it?
greybeard wrote:Gotcha. Somehow managed to completely miss that bit of the thread.
Anyone know if this can be done using R-net OBP or does it require the dongle?
Users browsing this forum: LROBBINS and 102 guests
