So thats not likely to be your problem. Although it could still be... Depends if the camera when in operation takes MORE than 2.1A.Upgraded Charging Technology - Auto detect your device and deliver its fully-intended charge speed up to 2.1A at most once connected.
but still the battery in the camera should still have a full charge i believe at that point either way -
Thats the sort of place you go early morning to eat your breakfast. And relax for a bit. And watch people go out fishing?
Burgerman wrote:Looks ok. Hard to tell on utube!
Burgerman wrote:You are using FWD stability algorythm to mask your hand control/coordination issues. Which is wrong. Rear drive is naturally already over stable. You should use 0% for rear drive or you get non proportional turn rate behaviour, and acceleration, dep on throttle/turn position.
And then add some tremor damping (under speeds) to aid the thing you are callimg instability. It removes the result of your hand jerking the stick due to your disability or technique.
its not me really but the chair over bumps etc, makes my hand move which in turn makes it unstable
it will differ for each user and how ever there chair is setup - there hands - etc
Burgerman wrote:it will differ for each user and how ever there chair is setup - there hands - etc
The ability and control capability may differ. But using a front drive algo to disguise the problem is always wrong. Tremor damping, and turn rates are the things you should be adjusting to make up for the differences. Preferably not turn acc/dec rates either.
Burgerman wrote:Or your chairs high seating means it must be a fair bit nose heavy for stability reasons. So the casters are quite heavily loaded compared to my chairs for eg. So yes you may need more pressure. But you are now learning to notice these things and figure it all out!
Users browsing this forum: DrewDigital, shirley_hkg and 150 guests
