Sinopoly Cells - Info -
Re: Sinopoly Cells - Info -
Postby shirley_hkg » 05 Apr 2018, 03:40
Average speed and top speed are really two different things . I pointed out long before he set out , that expresso could only do an average of 10kph .
Snaker is definitely a RECORD , that he pushed the stick for 7 hours ''NON-STOPPED ''.
I sneaked into the 2008 marathon here . It was boring , as you were un-accompanied throughout the game .
Postby expresso » 05 Apr 2018, 03:45
he sure is on top of his game there - :thumbup:
maybe he should look into the Guinness records etc, - i always wondered how that would work -
would they ride with Snaker and record the whole thing ? he may have a record he can get in the books
Quickie P222se - 60Ah ADD ON
Quickie S646se - 150Ah LifePo4
Quickie 636 - 200ah LifePo4
Bounder Plus - 180Ah LifePo4
Postby snaker » 06 Apr 2018, 03:09
Riding in long time is not that hard because our speed is VERY slow therefore our brain does not need to work hard. Unless we have a chance to drive BM3 at 26kph czy
And pushing the stick continuously in 7hrs or more is easy too. The key is that we have to find and locate the joystick pod at the right position. Once we feel comfortable with it, we can push the stick a whole day without feeling tired or hurt.
Postby ex-Gooserider » 10 Apr 2018, 04:35
Burgerman wrote:You just enter for fun. Your time wont mean anything since you are powered. But they wont expect it since other chairs cant complete the course. There will be lots of race manual wheelchairs. Some of those win...
I'm not sure what the W/C record is for the Boston Marathon, but I know that they start the W/C racers well before the AB types, and the W/C time is MUCH less than the runners. I seem to recall hearing that the race chairs can hit upwards of 30-40mph on some of the downhill stretches, so BM needs to figure out how to do a 100V pack if he wants to roll with the fast crowd cheers
Also worth noting that the top W/C racers are usually the leg amps, they sort of socket into their chairs like the old PlaySkool toddler toy dolls, and have the advantage of saving 30-40 lbs in non-working leg ballast off us SCI types...
Postby Burgerman » 10 Apr 2018, 08:37
I could fit a freewheel. But I am not cutting legs off to win a marathon. :ambulance
Postby expresso » 10 Apr 2018, 16:13
i guess i wont be winning any races then - i never though about those manuals - they do go fast and now you mentioned downhills -
i was thinking more along the lines of a wheelchair marathon - power only ? i never factored in the fast manuals and even fast runners -
Postby Burgerman » 10 Apr 2018, 16:49
They only go really fast downhill. Like a bicycle. Uphill is like, oops, whats gone wrong. Also like a bicycle! So on uphills you win. On downhills just make sure you accidentally get in the way a bit :D
Postby shirley_hkg » 17 Apr 2018, 15:04
drunk2
Postby expresso » 17 Apr 2018, 16:02
whow - this may change everything now - those will fit in the same size of the group 24 - how much are they ? now that i would love in my chair 170ah :thumbup:
Postby Burgerman » 17 Apr 2018, 17:03
These things appear!
But as usual, no supply available!
Also uninsulated. So casing is negative... Causes issues making a pack.
I would still be interested.
IF theres a regular reliable supply of new cells. Would nylon dip every cell. About 5x over to be sure. And seperate with 1mm plastic card, and 3mm on the base. Tape the lot up with duct tape. It will then be safe. These will be low C rate. So a large pack is essential. So you NEED 170Ah. But will work. So then...
From MK 73Ah you get about 40 to 45Ah out. So these will give 3.5 to 4 times as much range.
HOW to order 8?
Postby Burgerman » 17 Apr 2018, 17:25
To insulate you can tape them together temporarily, but add black RTV (bath sealer, silicone rubber) between each cell. Add 4 rubber washers between each as spacers. Leave to set. Sit the whole thing on a 3mm plastic base, and silicone that too as a permanent attachment. Test cells FIRST! You wont get them apart. Build as 2x 12V batteries. And seperate them with a rubber mat.
Then you end up with 2x lead brick replacements.
Postby Burgerman » 17 Apr 2018, 17:26
Postby expresso » 17 Apr 2018, 17:48
sounds like alot of prep. after adding all that - it may not fit size wise then ? i would want to be safe so its a must
Postby Burgerman » 17 Apr 2018, 18:15
Yes it will fit exactly!
Width wise, 255, we have 260 as per MK (or more on some chairs) Leaves room for 2mm sheet either side.
Thickness 41, 4 cells is 164. MK is 171mm, so we have 6mm spare. Thats 1.5mm sheet per cell. and /or siliconed.
Height, is much lower so space for a 8mm steel plate below, and a 3m plastic sheet for safety with ease.
It would be possible to fit 4 into an empty grp24 shell... And make a "battery"... Those are available too.
Postby Gnomatic » 17 Apr 2018, 21:33
Burgerman wrote:It would be possible to fit 4 into an empty grp24 shell... And make a "battery"... Those are available too.
Thats an interesting idea. Are you sure you could get 4 in a shell? With insulation between each one?
Postby shirley_hkg » 18 Apr 2018, 00:34
Rated 3C.
In stock .
Only @£53,while stock last .
Postby expresso » 18 Apr 2018, 01:03
what does that come out to in US prices - then adding shipping etc,
are these NEW ?
just curious for when time comes i will do another for sure
Postby shirley_hkg » 18 Apr 2018, 02:25
Burgerman wrote:Also uninsulated. So casing is negative... Causes issues making a pack.
HOW to order 8?
I think I've mentioned shipping rate somewhere buried down under ......
viewtopic.php?f=2&t=1813&start=3180
Postby Burgerman » 18 Apr 2018, 08:06
UPS air freight to UK :
21 --- 44 kg @ £5.8/kg , plus £55 additional charge for hazardous goods .
So 8S ? Total inc cells? czy
Postby foghornleghorn » 18 Apr 2018, 11:50
8 x £53 = £424
3.63kg each = 29kg
plus 5kg for packing = 34kg
34 x £5.80 = £197.20
+ £55 hazard
I think about £680+ Import Duty + VAT + any fees the carrier decides to add
Postby Gnomatic » 18 Apr 2018, 15:37
expresso wrote:what does that come out to in US prices - then adding shipping etc,
Assuming the shipping charges to US aren't much different than UK, it works out to roughly $920 to your door in USD. That included 8 cells, shipping, and the hazard charge.
Postby expresso » 18 Apr 2018, 15:40
thanks - thats a good price if the cells are new and they fit in the same space once packed and wrapped etc, - 170Ah - that would be amazing to fit inside - i wont need a ADD ON then :)
from the looks of things - i will end up having to do any new chair i get - if i even get a chair
Postby Gnomatic » 21 Apr 2018, 16:25
BM, do you know where these empty grp24 shells can be purchased? I can think of a couple uses for them.
Postby Burgerman » 21 Apr 2018, 18:28
I used to get all kinds of battery manufacturer spam. Since I sold batteries online. I remember some for empty battery shells, with lids not yet applied. They had 6 internal walls that would need removing. With a dremmel or similar. But no longer have these. So cant easily find now.
Postby foghornleghorn » 21 Apr 2018, 19:05
1. Does anyone know how durable something which has been 3D printed is? Wondering whether it would be possible to design and print a case with 4 slots the cells would fit in snugly.
2. Completely opposite to that, do the cells get hot in use and would they not really enjoy being fully enclosed? Just concerned as I have broken down before due to overheated electrics.
Burgerman wrote:I used to get all kinds of battery manufacturer spam. Since I sold batteries online. I remember some for empty battery shells, with lids not yet applied. They had 6 internal walls that would need removing. With a dremmel or similar. But no longer have these. So cant easily find now.
The only empty shells I have seen were in a classic car magazine designed to hide a new battery in a period looking case to keep the concourse originality fusspots happy. They weren't cheap.
Postby expresso » 21 Apr 2018, 20:31
https://www.simcobox.com/plastic-projec ... er_page=50
this place may have something or maybe can have it custom cut to size -
Postby Burgerman » 21 Apr 2018, 21:41
Not unless used at high currents. But it will reduce the C rating a little. Thats one reason the headway cells are higher C rated than prismatics. Metal cases and lots of surface area and airflow gaps.
Postby shirley_hkg » 22 Apr 2018, 14:24
drunk2
£10
Postby Burgerman » 22 Apr 2018, 14:43
Yes those. But we need grp24 size.
260L x 174W x 220 to 240 tall.
Postby shirley_hkg » 25 Apr 2018, 02:26
Found these good cells , and good price .. Reviews from buyers are ALL positive .
0.3mΩ rated @5C . 75Ah@£20.
May fit 16 of them in a G24 space . cheers :clap:
Hurry , while stock last .
Users browsing this forum: clairc, Google [Bot], pferrie, rover220 and 107 guests
