?2P9S
Gnomatic wrote:Well, I'd like 16 of those cells or similar, but want to first find a metal box I can fit them in.(after box has been insulated) I can make fit.
Burgerman wrote:Well thats EXACTLY how I treat my battery every day. So thanks for that!
Burgerman wrote:How did you get that price?
https://www.aliexpress.com/item/8Pcs-Lo ... autifyAB=0
£618 delivered for eight. And thats all you need.
The price of lithium continues to fall.
Thats for 100Ah. More than 2x the Ah you get from a pair of MK batteries, Which will only allow about half the 73Ah. Say 40 to 45Ah to be used at the high rates we use them. So price per usable Ah is already much less Because realistically thats the same as buying four MKs for range. That would cost £850!
And its better yet again, since these will last around 2000 cycles, or much better, instead of 500 at very best. Because if you only use the same range most days as before, they will give around 5000+ cycles, as you will only need to replace under 50 percent. Thats 10x more cycles. Or allow a charge every 2 or 3 days in winter.
Burgerman wrote:They may be a tiny bit taller. But otherwise they will fit. You will need a pl8.
terry2 wrote:So I would need a charger for the PL8 and then these. So about £1,000 all told. Will wiring them up be easy?(for me that is)
Users browsing this forum: No registered users and 223 guests
