FelipeOliveira wrote:This is de parameters that I have now
expresso wrote:i am not sure those are the original factory settings that comes with a 222se Chair - those chairs are 8.5 mph and wouldnt come stock with a 50A controller
at the very least it should be 80A the Qtronix and pilot plus 100A -
those are my settings i am using now - you can have a look - they are Ok - i only use profile 5 -
since going to RWD settings - much better on turning in motion etc. but can be a bit unstable front end - hard to say - since the roads here and sidewalks are bad - nothing is even here - alot of bumps cracks dips - sideways angles - either left or right - seems like nothing is really Flat straight
you have to change the Zip to Prg. to open it with the software
FelipeOliveira wrote:Ok I'll copy using the screenshots ...
I already inform the result
FelipeOliveira wrote:FelipeOliveira wrote:Ok I'll copy using the screenshots ...
this is the changed parameters. I insert one by one. now I'm going to test it. in about 10 minutes I inform the result ...
expresso wrote:FelipeOliveira wrote:FelipeOliveira wrote:Ok I'll copy using the screenshots ...
those are my personal settings - use them at your own risk - cant say for sure it will work for you or not -
Burgerman wrote:Were to begin... Language barrier.
I am not able to extract the files. windows tells u the folder is empty
Burgerman wrote:He has undoubtedly changed his high motor compensation settings for your 35mOhms. So his chair will feel like a slug.
Users browsing this forum: No registered users and 39 guests
