ZXD2400 modification guild 3Kw 0-60V 0-50A
Postby Williamclark77 » 21 Jul 2018, 00:03
Burgerman wrote::joint
Where is the smoke emoji?!?
If you care, they come with a fancy case that you transfer everything into. I did one already.
Here, scroll...
viewtopic.php?f=2&t=7670&start=60#p119458
I read over it. Yours and Shirley's recommendations sold me. Both of you are better at electrickery than I am.
WcMade.com - Get nearly anything you need made
Williamclark77
Postby shirley_hkg » 21 Jul 2018, 02:34
Here, scroll...
I read you PM , and will put yours in my next bin .
The modified PSU comes with copper power poles , good for 20A plus . 4mm banana plugs too.
The fency outfit is not a must , and there is quite a job to put on it. Not recommended to novice . cheers
I'm not a fans of it . :wave:
LROBBINS wrote:Arrived a few minutes ago. One month exactly from payment till arrival and only 7 days from when it was shipped - that is very fast. I am up to my eyeballs, as usual, in too many projects, so all I've done is power it up and saw that the display comes live and the (indeed noisy) fans run, then put it back in the box and on the shelf. BTW, to my eyes the stock rack mount case is not all that ugly, though I did buy the fancy case and will eventually move it over and add an Anderson.
Total price remains very, very reasonable for a 3000 Watt bench supply/charger. Do I owe you anything to cover the PayPal fee?
Thanks,
Lenny
Postby Burgerman » 21 Jul 2018, 02:55
Thats why mine has the usual Anderson connectors added. Those 4mm are not really enough for more than 20 to 25A. I can feed 40 to 50A to the PL8 Cellpro. Or to fast charge a chair, rapid charge my van, all via andersons.
Postby martin007 » 24 Jul 2018, 23:34
> CP900866055HK
Postby Burgerman » 24 Jul 2018, 23:41
Yes. S l o boat...
Postby martin007 » 24 Jul 2018, 23:55
I think (I hope) that the month of August will arrive.
Postby Burgerman » 25 Jul 2018, 00:14
Which august? Maybe next year! S L O boat. :fencing
Postby martin007 » 25 Jul 2018, 00:33
The previous orders (some) took 1 month to arrive.
Postby shirley_hkg » 25 Jul 2018, 03:59
Standard delivery in working days :
download/file.php?id=5906&mode=view
Postby martin007 » 25 Jul 2018, 12:05
"Surfarce Parcel 43 - 58 days."
From the day of the posted????
Postby shirley_hkg » 25 Jul 2018, 16:33
Postby martin007 » 25 Jul 2018, 17:32
I think the package will arrive in August.
Postby Burgerman » 25 Jul 2018, 17:34
But they didnt say which August. :shifty:
Postby martin007 » 25 Jul 2018, 17:37
30 June + 58 days = August.
Postby Burgerman » 25 Jul 2018, 20:17
Thats an estimate... Depends on wind! :fart
Postby steves1977uk » 25 Jul 2018, 20:18
My 2nd PSU is on the slowboat... :mrgreen: :thumbup:
Postby martin007 » 25 Jul 2018, 23:39
Depends on wind!
:shock: :shock: :shock: :shock:
Oh my god!
Postby Williamclark77 » 27 Jul 2018, 13:27
I sure would like one of these. Shirley is holding out on me.... :cussing
:lol:
Williamclark77
Postby shirley_hkg » 27 Jul 2018, 14:48
Kind of busy lately . Will do when time allows .
Postby shirley_hkg » 28 Jul 2018, 09:53
To US members of forum , please be advised that this PSU's ampere will be reduced to half , when used in USA 117V.
Gnomatic may have something to share .
Postby Burgerman » 28 Jul 2018, 10:29
You may be right. But it may be that the watts are reduced by half, but at under 30V it may still do 50A.
Postby shirley_hkg » 28 Jul 2018, 14:21
The guy who make this kit said the amp is reduced .
Another point is the same kit can have a 120V unit , though the capacitors need replaced .
Postby Gnomatic » 29 Jul 2018, 03:25
I don't have anything definitive to offer yet on that specific question.
Postby shirley_hkg » 29 Jul 2018, 06:49
steves1977uk wrote:https://translate.googleusercontent.com/translate_c?act=url&depth=1&hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=auto&sp=nmt4&tl=en&u=http://diy.lgm3361.com/zxd2400/3/&xid=25657,15700023,15700124,15700149,15700168,15700186,15700189,15700190,15700201,15700205&usg=ALkJrhiEpGE3pPSx2zOTsvypO_2h0w8c8w
Still can't believe it's compact size! :)
Great job by Steve . cheers :worship
@ex-Gooserider : did you go through what Steve has done for us ? goodpost This is the best document we have . goodpost
Postby ex-Gooserider » 31 Jul 2018, 01:22
I have skimmed through the document Steve did, and the rest of the thread - but haven't done in detail, as I figured it wouldn't make a lot of sense until I have a unit in front of me...
I actually have several fixed voltage supplies for running my PL/8 and similar sorts of things, so the lower amps out due to 110V US power isn't a big concern. My primary interest is to have it as a variable CV-CC bench supply that I can use for testing things that need more juice than the supplies we have currently in the Asylum electronics shop...
Postby Burgerman » 31 Jul 2018, 01:37
Well mine is currently charging in parallel, a pair of OLDER odyssey batteries in a chair I leant someone. Its set to 40A, 14.5V, terminate at 0.3A, (its warm) and float at 13.6V and it isnt any louder than charging at 12A on the salsa. It doesent seem to get warm even charging at 40A.
Postby shirley_hkg » 31 Jul 2018, 02:17
ex-Gooserider wrote:I actually have several fixed voltage supplies for running my PL/8 and similar sorts of things, so the lower amps out due to 110V US power isn't a big concern. My primary interest is to have it as a variable CV-CC bench supply that I can use for testing things that need more juice than the supplies we have currently in the Asylum electronics shop...
You should consider the 120V25A version , if large amps were not your priority . :clap
Postby Burgerman » 31 Jul 2018, 09:56
I have 2. I can set 60V on both, and connect in series. I then have 120V 50A DC power supply! Or set 1 at 30V and one at 60, and have 90V DC. Etc.
I do this now with my other two big SM40 bench supplies. But in parallel. So if I want to charge fast, I have 80A up to 40V.
Postby shirley_hkg » 31 Jul 2018, 10:50
ex-Gooserider wrote: My primary interest is to have it as a variable CV-CC bench supply that I can use for testing things that need more juice than the supplies we have currently in the Asylum electronics shop...
This unit can tell at anytime the C.C. / C.V. values you've set , while normal bench supply can tell C. C. only when under load / C.V. when off loaded .
goodpost
Getting more interested in this crazy cheap little thing . :ebay
Postby Burgerman » 31 Jul 2018, 12:55
Seems to work fine as a power supply even if set to 3 stage charge. As long as termination set to .2A (or .3 for a pair of batteries in parallel 12v) So I leave it that way.
Users browsing this forum: shirley_hkg and 54 guests
