Manufacturers prefer Yugo.
Hovercraft.
“Dear Sir, Thank you for your enquiry. The programming tools are only available for Dealers and OEMs trained in their use. They are not available for end users or their families.”
Burgerman wrote:READ post 1, 2, 3, 4 etc.
CAREFULLY. As you have it it wont steer.
4) Do I copy your "profile management" settings, you've not highlighted them in yellow?
5) Also what about the "configuration settings"? Do I leave as is?
Burgerman wrote:4) Do I copy your "profile management" settings, you've not highlighted them in yellow?
Depends what you want, what you are trying to achieve, how many profiles you want or need and why, and what equipment you have plugged in.
Ask one setting at a time because theres a zillion options and combinations. Dont change stuff you dont understand, ask first!
Also you can read in the manual for r-net about what/how. It tells you everything!
THE REASON I WANTED TO REPROGRAM THE CHAIR IS TO MAKE IT STEER MORE RESPONSIVELY. The OEM setting is a bit woolly.
foghornleghorn wrote:Where did you manage to purchase a dongle?
Burgerman wrote:Also the TORQUE setting if set too high makes the initial movement too jumpy. It add motor power at very small stick movements
foghornleghorn wrote:Cat - unless I'm getting people confused, Scooterman does have one.
hank wrote:Done about 6 miles in chair today with forward acc 100 And min forward acc 100 Rnet 120amp
Much more lively now and responds well.
Burgerman wrote:Thats where all my chairs are set.
On my chairs
forward accel is 100
min forward acc is 100
reverse acc is 100
min reverse acc is 100
back stick brake or fast brake is 90
turn acceleration 100
min turn acceleration is 100
turn deceleration is 100
min turn develeration is 100
forwards decel is 20
min forward dec is 20
revese deceleration is 20
min reverse decel is 20
Scooterman » Thu Nov 15, 2018 10:07 am
I'm getting there.
So far I've got
max turn acc 90%
max turn dec 90%
max fwd acc 50%
torque 50%
But I've got the:
min turn acc & min turn dec set much slower.
But with min turn acc/dec I've set it low to stop the chair whipping round at 1 bar led. Fast turns when slow/stationary upset my knees because my legs wobble about (no muscles).
Users browsing this forum: ex-Gooserider, robert97, shirley_hkg and 74 guests
