steves1977uk wrote:Easiest way... https://www.sordum.org/9480/defender-control-v1-4/
Of course there's other ways like you and me know BM But I'm trying to keep it simple and straightforward for SM
Burgerman wrote:For future reference.
Open any image editor or viewer.
Burgerman wrote:http://www.burgerman.info/
Also worksin case anyone cares. For at least 15 years?
Burgerman wrote:Depends what that crack actually does. Some have a few options. And they re run the activator automatically every few days so you aways have 6 months to go. Some use volume licence keys, and good to go forever theoretically. Some need to be rerun manually every 6 month or sooner.
SM, try the attached Win10 activator, this one renews itself via the task scheduler. Extract and run the cmd file as administrator.
Dont install a crack that sets a scheduler that run every day and eat up CPU cycles and your computer will run slow.
Thats a bad idea...
Which is why I said:Dont install a crack that sets a scheduler that run every day and eat up CPU cycles and your computer will run slow.
And CPU will sit at a 3 or 5 % high percentage at idle
If you did this, go to the task scheduler, find the entry and delete it... Or disable it. And run it only after you get a 180 day warning. Then disable it again. Or it starts running every logon, and then conflicts with the "system interupts" all day long.
<?xml version="1.0" encoding="UTF-16"?>
<Task version="1.3" xmlns="http://schemas.microsoft.com/windows/2004/02/mit/task">
<RegistrationInfo>
<Source>Microsoft Corporation</Source>
<Author>Microsoft Corporation</Author>
<Version>1.0</Version>
<Description>This task restarts the Software Protection Platform service when user logon occurs</Description>
<URI>\Microsoft\Windows\SoftwareProtectionPlatform\SvcTrigger</URI>
<SecurityDescriptor>D:P(A;;FA;;;SY)(A;;FA;;;BA)(A;;FRFW;;;S-1-5-80-123231216-2592883651-3715271367-3753151631-4175906628)(A;;FR;;;S-1-5-4)</SecurityDescriptor>
</RegistrationInfo>
<Triggers>
<LogonTrigger>
<Enabled>true</Enabled>
</LogonTrigger>
</Triggers>
<Principals>
<Principal id="InteractiveUser">
<GroupId>S-1-5-4</GroupId>
<RunLevel>LeastPrivilege</RunLevel>
</Principal>
</Principals>
<Settings>
<MultipleInstancesPolicy>IgnoreNew</MultipleInstancesPolicy>
<DisallowStartIfOnBatteries>false</DisallowStartIfOnBatteries>
<StopIfGoingOnBatteries>false</StopIfGoingOnBatteries>
<AllowHardTerminate>false</AllowHardTerminate>
<StartWhenAvailable>false</StartWhenAvailable>
<RunOnlyIfNetworkAvailable>false</RunOnlyIfNetworkAvailable>
<IdleSettings>
<StopOnIdleEnd>true</StopOnIdleEnd>
<RestartOnIdle>false</RestartOnIdle>
</IdleSettings>
<AllowStartOnDemand>true</AllowStartOnDemand>
<Hidden>true</Hidden>
<RunOnlyIfIdle>false</RunOnlyIfIdle>
<DisallowStartOnRemoteAppSession>false</DisallowStartOnRemoteAppSession>
<UseUnifiedSchedulingEngine>true</UseUnifiedSchedulingEngine>
<WakeToRun>false</WakeToRun>
<ExecutionTimeLimit>PT0S</ExecutionTimeLimit>
<Priority>7</Priority>
<RestartOnFailure>
<Interval>PT1M</Interval>
<Count>3</Count>
</RestartOnFailure>
</Settings>
<Actions Context="InteractiveUser">
<ComHandler>
<ClassId>{B1AEBB5D-EAD9-4476-B375-9C3ED9F32AFC}</ClassId>
<Data>logon</Data>
</ComHandler>
</Actions>
steves1977uk wrote:SM, try the attached Win10 activator, this one renews itself via the task scheduler. Extract and run the cmd file as administrator.
I only use the windows partition for mob equip programming
Scooterman wrote:That seems to have done the trick Steve
It was really easy.
I only use the windows partition for mob equip programming so if the widget file slows down my cpu a tad I'm not bothered. And Steve's fix seems to have worked well and was really easy to do for someone like me.
Users browsing this forum: Bing [Bot] and 8 guests
