Burgerman wrote:Are you refering to 6.3mm spade terminals?
Burgerman wrote:Good to know. Heatshrink is a little thinner. Should be perfect.
rover220 wrote:Burgerman wrote:Good to know. Heatshrink is a little thinner. Should be perfect.
indeed, also worth noting the finger in the picture is pointing to to the 2 inhibit channels in the module
http://marketing.sunrisemedical.com/Tec ... Manual.pdf
Theres a newer version of this, but the ISM connections are on page 133 -- I have used that before to figure stuff out. Elsewhere it explains the programming. 5 channels are usually used for tilt, footrest length or footrest angle and individual footrests angle along with recline, lift, leaving one unused. You can rename that to whatever you want like Pee! So it shows up as this on your colour display.
funkykeyboard wrote:Well I have used this dongle in the past to program my attempt at copying your wheelchair. I've also plugged into this one I think. But I'm getting nowhere at present.
I have tried two different USB cables. I have tried it on both wheelchairs. No joy.
https://youtu.be/7801D1foi_A
Any advice appreciated, Tremulous Tetra. :-)
daunjan wrote:Have you seen this one https://www.freedom-flow.com/
https://youtu.be/aCEuEUj4hWc
Just spotted this after above post
snaker wrote:A solenoid valve only allows a tiny flow, just a few drops per minute. You need a day to empty your bag.
Why not try a tiny 24V diaphragm pump as BM recommended. It is small, light and quiet. Importantly, it works!
I empty a 500ml bag in 30s. In real use, it never exceeds 15s.
https://youtu.be/jr1KOUZOvFo
Irving wrote:snaker wrote:A solenoid valve only allows a tiny flow, just a few drops per minute. You need a day to empty your bag.
Snaker is right, that 2.3mm bore will give a flow rate of less than 0.1 litres/min (i.e. 8min to empty a typical bag) assuming you could get the flow started (about 5Bar pressure needed - might do some damage to bag and/or bladder!). You need approx 8mm bore to empty the bag by gravity in around 30sec.
A pump is the way to go, though I'd have some concerns about how well it seals when not powered on.
Users browsing this forum: Qvickster and 18 guests
