Burgerman wrote:And lead. Was originally the hyperion. They were keen to learn and I did a LOT of beta testing and talking to them. Very responsive company. But it turned out unreliable and the guy running the company's son had an accident and kind of went offline for a few years and they stopped making them at least for a bit. So I was looking for a replacement.
The PL8 existed but was so safety nazid down, and its settings were so restrictive that it was a nightmare. And it wouldnt allow many settings we needed, had a bunch of bugs or "features" in firmware that prevented charging Lead properly. And the same with LiFePO4.
So I spent a lot of time trying to get them to fix stuff and hundreds of emails. They didnt exactly work with me and it was more argument than a helpful response. In the end, they changed a bunch of things in a firmware update once they figured out I might be right, that allowed it to be used for lead/LiFe properly. And changed some presets. The problem is that they want to make 1000 excuses as to why their way is safer. But too restrictive. Because they are dealing with hobby idiots that are exploding LiPo batteries and burning down houses. And we found a way to mod the presets too, to allow a few wider settings than appears on the CCS software internally. 2 years of partly adverserial contact with their beta tester. So PL8 is now good! But it was hard work... So I bought 4.
it does NOT go past 3.657v
2nd - i charged the bounder and just monitored it with the pl8 - i never seen the volts go past 3.657v on the PL 8 and the graphs shows that
that was the end of the charge cycle --
expresso wrote:- if not - charger will stop either way - it will only restart if pack volt is below 27v
charger can stop and restart based on the BMS - during the charge up to its set 29.2V - once it hits that - thats it - done - -
expresso wrote: -
i watched it get to 29.2V on the PL8 - on the graph you can see it reached a high of 3.657v - before it stopped
as long as it works and takes me where i want to go
i stopped the PL8 myself at this point - since there is nothing else thats going to happen
- i understand whats happening and why the BMS does it this way
- it may be bad and stupid etc, etc, BUT it dosnt matter - unless BMS get better at this and unless the industry changes how they make them - and they wont - they are working the cells to there MAX on both ends of the spectrum -
its a dumb charger like all the rest - CC CV and done - it may have a mechanism that works along with the BMS to turn on and off etc, or it may not have nothing and BMS is in control - which is what i believe -
Users browsing this forum: No registered users and 102 guests
