Burgerman wrote:Only the joystick being "odd" then. Since the OEM R-Net works, it must use the same internal electronics. Why? It must cost them extra to confuse people with what can only be described as an ugly and likely well overpriced joystick! And then the stock joystick must be ok to retro fit.
So if you prefer it, or your oddball 10 one goes wrong then logically the advanced colour one will be plug and play, with no need to even reprogram anything.
https://www.cw-industrialgroup.com/Prod ... ules-CJSM2
Elryko has 2 for sale new...
I only need it to output a signal from a connected joystick to the Tecla.Joystick is on one of the inputs nothing on second Omni input.
The Tecla takes an input from a connected switch
and outputs a bluetooth command to an ios device.
If I can figure it out the input command is from the joystick.
If the joystick is connected to the Omni then the Omni needs to connect to the Tecla (or R Net).
Tecla support article https://gettecla.zendesk.com/hc/en-us/a ... ls-tecla-e says use an IOM but I already have the Omni.
If the Omni doesn't have another output port I guess I will have to add an IOM. Or just buy the R Net bluetooth module.
Users browsing this forum: Jay_x, mentado020477 and 36 guests
