shirley_hkg wrote:I did the modification myself last month, with thick wires and ring terminals.
Burgerman wrote:No...
His is the stock unit. Yours has the fancy case. He has fitted an ANDERSON at the front, powered by the stock banana connectors on the rear shown here!
I put the rear cover back on and left it for now. It would be nice to do but I don't want to mess it up and am fearful of stripping it down to get better access.
Burgerman wrote:I think BM means bi-wires at each Anderson pin ; as a Y-spliter.
Yes. Strip 1.25 inch of insulation in the middle of a wire. Easy on silicone as its soft. Fold wire in half. Insert into Anderson connector pin and crimp/solder.
Supply >>>>>>>>. Anderson >>>>>>>>front connectors
Makes the fight for space etc easier.
shirley_hkg wrote: Another two ZXD2400 were out , for Australia .
martin007 wrote:Has anyone modified the charger to make the fan quieter?
steves1977uk wrote:BM, which dremel and metal cutting discs do I need to buy?
Thanks,
I replaced both fans with super quiet ones with their own temp sensors. Very quiet, but cooling may be marginal for large LiFePO4 packs (those that sit at 50A for a long time). Details are in an earlier post of mine in this thread.
Scooterman wrote:steves1977uk wrote:BM, which dremel and metal cutting discs do I need to buy?
Thanks,
If/when you get a dremel (or similar) Steve, can you post which one you got. I've always wanted a multitool but never have bought on cos I don't know which one to buy.
Users browsing this forum: martin007 and 52 guests
